Hotpoint wdl520 damp smell - Washing Machines
How do i clean Hotpoint aquarius WDL520
Run clear no soap water threw 2 or 3 times then should be fine
CLR if you have rust stains rinse good
Dec 03, 2014 | Hotpoint Washing Machines
Hotpoint wdl520 aquarius not switching on!
hi if you are getting no power at all and fuse in plug good i would check interlock that is were door locks in next is control panel usually interlock is cause
Jan 01, 2014 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wdl520
IT IS AN OLDER STYLE HOTPOINT WHICH MEANS YOU ACCESS IT FROM UNDERNEATH.YOU NEED TO REMOVE THE RUBBER PIPE FROM THE DRUM AND INSIDE THERE IS A BALL AND CAGE.REMOVE THE CAGE CLEAN IT OUT AND REPLACE IT THEN THE BALL AND REATTACH THE RUBBER PIPE.
Jun 25, 2013 | Washing Machines
I need to a manual for hotpoint aquarius WDL520 washer dryer
you can download the instruction manual from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Hotpoint Aquarius WD640 Front Load...
I NEED A MANUAL FOR HOTPOINT AQUARIUS WDL520G
You should be able to download the user manual from the following site: hotpointservice.co.uk/pages/manual
Or directly download from this link: Hotpoint/Laundry/WDL520 (pdf)
Hope helps.
Sep 25, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
I need a manual for an aquarius wdl520
You should be able to download the user manual from the following site.
WWW.HOTPOINT SERVICE.CO.UK
In the menu, click on>>
Hotpoint user instructions.
Then in the search box enter your model number
Please rate my solution.
Thankyou.
Jan 28, 2010 | Hotpoint Washing Machines
Where can I download a copy of User Operating
check the hotpoint web site some manuals available
Nov 11, 2009 | Washing Machines
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
