Question about Electrolux Vacuums
How to remove wheels from electrolux ergospace
2 Suggested Answers
  • 530 Answers
SOURCE: My Electrolux Ergospace is blowing instead of
Clogged filters.
Posted on Oct 29, 2014
How to fix a broke cable inside a reel in Electrolux Ergospace ZE2262
If the vacuum runs well with no other problems it may be worth buying a new cord reel. It may be less expensive to purchase a new vacuum but it may not last as long as an older machine. I have many 10 to 20 year old vacuums brought into my store for routine maintenance. Do not try to replace the cord as you are correct, the spring come flying out.
Mar 24, 2014 | Vacuums
Electrolux vacuum ergospace stop working how to fix
I am not too familiar with this particular model but I would think the cord winder may be shorting out. I think you can take it apart by turning it on its side, pull the side strips off. It is a bit tricky but if you access the winder check the electrical conitinuity from the winder to the plug in cord. You are probably better to take it in but if you cant please be careful to not get a shock..
Jan 16, 2014 | Electrolux EL4100A Ergospace Cannister...
Remove BACK WHEEL,DOESN'T TURN WELL
You will have better luck if you mention what model it is and post a web link to a picture.
Oct 06, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
How to replace the wheels on my old electrolux
If you look at the bottom you will see that they are held in place by a Phillips head screw. Remove and replace as required.
Aug 13, 2013 | Electrolux Guardian Bagged Canister Vacuum
How do i get into the electrolux discovery II powerbrush assembly? I have removed all screws but still no access?
There are two square holes on the outer side of the wheels. Use a flathead screwdriver in these to release the latches. Turn the powerhead over and carefully lift the back of the cover off and pull back slightly to lift off. To remove the brush and/or replace the belt, remove the tiny screw on each end of the brush and lift brush out.
Mar 20, 2011 | Electrolux Vacuums
My Ergospace Vacuum took some apple juice in and now it makes strange noice and even threw out some sparks. Is there anything I can do my self or is it over with this vacuum cleaner? I opened 6 screws, but...
Liquid plus electrical parts always ends up with the electrical parts losing. Juices, although they will dry, will leave behind a sticky residue. You'll need to replace at least the motor, but due to the other electrical components, probably be better off replacing the whole thing.
The hidden screws are beneath the control panel. There are two tabs beneath the panel cover. Using a thin bladed screw driver release these to pop of cover. You may need to use a flashlight to be able to see the tabs and make sure they get released. If the tabs break, the cover won't stay on. Under the cover are two screw that need to come out.
There are two more tabs in the bag well that need to be released. Remove the bag and at the top of the back of the tank you'll see two tabs. Do so with a screw driver. After this the top of the machine can be lifted off with some manipulating.
There are electrical motor spray cleaners you can use to try to get the residue off the motor, but it's doubtful you'll be able to remove it all.
Dec 11, 2010 | Electrolux EL4100A Ergospace Cannister...
Electrolux 6985A wheel (the one on the cord side) is sticking. How do I remove it to clean out the hair or whatever is making it stick?
Most of these wheels have a push fit. the larger the diameter the tougher to reach the axle portion, but it generally has a flex cutout on at least one side which you can push in slighlty with a long flat screwdriver. Try spraying with WD 40 or silicone spray rather than remove the wheel
Oct 30, 2009 | Vacuums
Electrolux z4494 vacuum cleaner mains cable wont stay out
Opened up case as follows:
- Open lid of bag chamber. Remove lid by gentry prising the hinge arms slightly further apart so the hing unclips from the body.
2 deeply recessed screws now accessible at rear edge of bag chamber - undo.
Prise out large button of on/off switch to reveal another screw - undo
Prise out large button of cable retract to reveal another screw - undo.
Cover now lifts off.
Inside I found the brake wheel had fallen out of its plastic bracket. The plastic bracket is hinged, and moved my pressing one end with the big button, which lifts the wheel away from the cable drum. Gently prised the bracket arms apart and put the brake wheel back in.
Solved it - but don't know why it happened, or whether it is likely to happen again.
Sep 01, 2009 | Electrolux Vacuums
How do you access and then repair the cord winder on an electrolux canister vacuum cleaner?
Is it the long type, 2 wheels on the back, one swivel wheel on front?
Aug 02, 2008 | Electrolux Vacuums
Vacuums Logo
41 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
