Question about GE DGE505N Multi-disc DVD Player
OPEN CLOSE NOT WORKING IN DISPLAY SHOWING LOC IN LG DV456 MODEL
The buttons on my Lg bd550 dvd player dont work
If a disc in the unit it may have jammed something in the mechanism---someone would have to open and visually inspect the loading mechanism first.
Oct 16, 2012 | LG BD550 Blu-Ray Player
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Usv pen drive of lg dvd model dv456 is not accessing .avi files
    you need to format the .avi files to mpeg format or any other supportable formats by your computer. to format the files download format factory.
    1)go to www.google.com
    2)type u torrent & download from the available sites.
    3)install u torrent.
    4)now go to www.torrentz.com
    5)search for format factory.
    6)download that is verified. if none is verified, download the recent uploaded file.to downloadf go to any of the the available sites and download the torrent file. install it or open it through u torrent. press 0k >ok.
    7)now wait for the download to complete.
    8)right click on the file and select open folder. install.
    9)format the file. and copy it to pendrive.now go for it & enjoy.
    Dec 24, 2010 | Televison & Video
    I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
    Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
    Range - "LOC DOOR" flashes in the display
    If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
    Motorized Switch
      1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
      2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
      3. While you hold the door jamb switch in this position, complete the following steps.
      4. Press the Clean pad, wait 10 seconds.
      5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
      6. Wait 10 seconds for the display to clear.
      7. The door should unlock and there should not be a need for service.
    Manual Switch
      1. Press the Clean pad.
      2. Close the door.
      3. Slide the latch to lock the door.
      4. Hit the cancel button immediately.
      5. Unlock the door.
    Motorized Switch
    Manual Switch
      2. Close the door.
      5. Unlock the door.
    Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
    Oven Door panel is showing LOC position but can be opened and closed so not locked. Unable to use oven for cooking
    What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
    Mar 18, 2010 | Kitchen Ranges
    HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
    EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
    6871JK1011D PCB Assembly,Main /
    WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
    WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
    SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
    SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
    60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
    C 3 60W to 40W
    Jun 12, 2009 | LG 22 Cu. Ft. French Door Refrigerator,...
    The display shows "Loc" and the oven will not work. It earlier displayed E1 F5 and the door would not unlock. I unplugged the stove and plugged it back in, and the door openned. Now it displays "Loc" and...
    sounds like the control panel may be locked, look for an icon that looks like a small padlock, push and hold it until the loc goes away, it says 3 seconds but 5-8 is more realistic. I hope this hepls
    Apr 12, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
    I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
    For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
    Dec 24, 2008 | Sanyo DWM-390 DVD Player
    Doot lock problem
    Hold the lock button for 3-5 seconds...
    Mar 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
    Lighting the oven
    Control Lockout (on some models)
    Your control will allow you to lock out the
    touch pads so they cannot be activated when
    touched or cleaning the glass panel.
    To lock the controls:
    Touch the 9 and 0 touch pads at the
    same time for 3 seconds until the
    control beeps twice. The display will
    show LOC continuously and the time
    of day if not blacked out.
    NOTE: All cooking and timing functions will be
    cancelled when locking out the control.
    To unlock the control, touch the
    9 and 0 touch pads at the same time
    for 3 seconds until the control beeps
    twice, and LOC will be removed from
    the display.
    NOTE: Some models have a Control Lockout
    pad. Touch and hold it for 3 seconds to
    lock/unlock.
    Gas/Control Lockout (on some models)
    surface burners, oven burners and control
    panel so they cannot be activated.
    To lock/unlock the controls:
    Turn all surface burners off.
    Touch and hold the Gas/Control
    Lockout pad for 3 seconds until the
    display shows LOC ON.
    To unlock the control, touch and hold the
    Gas/Control Lockout pad for 3 seconds
    until the display shows LOC OFF.
    When this feature is on and the touch pads
    are touched, the control will beep and the
    display will show LOC ON.
     The control lockout mode affects all
    controls. No controls will work when this
    feature is activated.
     The adjustment will be retained in memory
    after a power failure.
    Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE DGE505N Multi-disc DVD Player Logo
    18 people viewed this question
    Top GE Televison & Video Experts
    Computer Repairing
    Computer Repairing
    matt martin
    matt martin
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
