Question about Pool & Spa
Onga ultra 4700
SPA WONT HEAT UP COULD THE PILOT BE OUT
3 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: spa wont heat
Check the pump make sure that it is getting power. If there is power to the pump and nothing is working then pump is bad. Also this could be your computer board is bad, a inline fuse. or the Jandy is bad
Posted on May 20, 2009
SOURCE: I want to heat the
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Posted on Apr 02, 2010
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
Does the onga spa master 4352 have a fuse or overload switch?
try to reset breaker if not blown check to see if there is a fuse after that probably a bad capacitor on motor or bad motor
Aug 19, 2014 | Pool & Spa
Hayward spa pool heater pilot on, heat does not ignite burners
Don't really think the gas company would be checking your pool heater, they most likely just checked their gas connections. I would suspect a few things; control module, thermostat, gas valve, pressure switch. You say you get pilot light, and as long as it doesn't turn off and on, as if it is not being sensed, then I would suggest the control module is fine. If the pilot and main burner is controlled by the same valve, and your pilot light stays lit, then I would suggest the thermostat is fine. I take back the pressure switch since the pilot will ignite. I would check power to the gas valve solenoid and see if the control module is trying to open the gas valve. I would suspect low voltage, probably around 24v. If voltage is present and no gas, I would say you found the problem.
Apr 09, 2013 | Hayward H Series Pool & Spa Heater...
The heat wont turn on and pilot does not stay lit
If this is a M/V heater you must have at least 400mv/dc to hold the pilot valve open. Check to make sure that the pilot is lighting, then hold the pilot valve down for about a minute. If the the pilot goes out you need to see what the m/v reading is. Chances are you have a bad pilot or gen. Replace.
Mar 06, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot fires then quickly shuts off how do I pull a code on a Takagi T-K2?
Pilot must heat the thermocoupler a couple of minutes before letting go of the button. The coupler controls the main valve.
Jun 12, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Pool & Spa Logo
90 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
