First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
Justice moris if you are Technician, go ahead otherwise show some official repairer to fix it, for the heating, problem is a charging ic water damage or broken, so change the charging ic near the battery connector and if problem persist change resistor near charging ic. this solution 90% helped in this kind of cases, if my answer was helpful please rate it, also you can search on gogle.com for the charging ic ways. Bes of Luck.
First Option:Please change The Phone Bettery and charger and check The check The Phone charging IF Charging Problem will Not Solved So Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
i think the problem is on the IC, try to check the power IC and the CHARGING IC,, if you dont know you better go to the technician, tell him to check to power ic and charging ic, there is a short in there
1st check yur charger if yur charger is ok then check the charging socet if both ok then change , resold , or reball the charging ic it will charge properlly
if u r cell showing charging indicator onscreen
and actualy it not charge battery,it means problem in charging ctrl ic check rasister near charging ic and finaly heat charging ic with using flux and hotair gun
