Question about Mtd 22" Yard Machine Push Mower
Yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Changed air filter and spark plug. wanna change oil CAN NOT locate drain plug. also, will need to drain gas.
  • Anonymous Apr 01, 2014
    wont start if i putgasin carb it will run for 2 seconds i sprayed card cleaner new gas spark plug still wont start
  • 205 Answers
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
Yard machine riding lawn mower
The dead-man switch on the lever (that you have to hold in to keep it running) has a loose connection or you have a loose spark plug wire.
Aug 18, 2014 | Yard Machines Garden
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
How do you drain the oil and gas out of this mower mtd 22' 4hp and how do you change the spark plug? do you need any special tools/thank you soooo much natalie
Drain plug for the oil should be under the deck next to the blade shaft. Usually a plug with a square head on the bottom of the motor. Loosen the fill plug and then remove the drain plug. Any time you go under there make sure you disconnect the spark plug wire so no spark can jump.
Gas is another thing. No fuel line as carb is part of the tank, so only way to empty is to .....
1) tilt the mower over and pour out the gas. Good time to change the oil and do it before you add the new oil.
2) unbolt the tank from the motor and remove tank carb and all a single unit. Then turn it over and dump the fuel. there are only 2 bolts holding it on so after you remover the air filter you can see them easily. Just remember how the throttle linkage hooks on.
May 21, 2010 | Mtd 22" Yard Machine Push Mower
Lawnmower won't start
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Where do i change the oil on 5.5 hp. 21 inch cut mtd push mower
Most of these machine will have an oil drain plug under the mower deck near the center of the blade. 80 to 90 % of them are a 3/8" drive female plug that can be removed with a ratchet and a short extention.
When you put it back in it is a good idea to clean it well and wrap the threads with 2 or 3 layers of teflon tape
Apr 04, 2010 | Mtd 22" Yard Machine Push Mower
Oil change in yard man lawn mower. i am unable to find a drain plug
Some mowers are designed to drain oil out of the dipstick tube. remove dipstick and tilt the mower to allow oil to run out into a drain pan. 2/3 rds of a quart or 20 oz is what to expect.
Dec 05, 2009 | Mtd 22" Yard Machine Push Mower
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
791 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
