Hp fmb 0701 - Computers & Internet
Hello. I recently bought a new motherboard, fmb-0703; and windows will not load. It starts, but does not fully load. I'm running windows 7 pro 32 bit. Bios boots, every works except windows
I could be a couple of things. If it is not loading correctly More than likely something to do with memory either motherboard ram or video ram. try a live boot cd and see if it loads like hirams boot cd with live windows. it is free. also you can the motherboard and ram and hard drive the the live cd to pinpoint hardware problems. just a thought. good luck.
Jun 01, 2015 | Intel Computers & Internet
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
I need the 4 digit code for my memorex TV
memorex TV 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701 OR 0002, 0502, 0506, 0706, 0115, 0704, 0601, 1302, 0428, 0632, 0701
Aug 16, 2011 | Philips PM3S Remote Control
Error 0701: USB Over Current on HC/Port
Error 0701: USB Over Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Sep 28, 2010 | Lenovo 3000 C200 Notebook
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Error code 0701/8000/4005 (sky player) sky movies on xbox
Yeah I'm now stuck to and the net has nothing coming up besides this query. Sucks
Feb 20, 2010 | Microsoft Xbox 360 Console
Error 0701 problem in lenovo laptop 3000 c series and N
Try turning on the computer in safe mode and turn on the computer by pressing f8 and see if that works. check in the bios if the cd drive is detected make sure that the disk you put in cd drive is a bootable disk
Jan 09, 2010 | Lenovo 3000 N100 Notebook PC
Saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Oct 26, 2009 | Saeco Royal Digital Plus Coffee...
Error 0701: USB Over Current On HC/Port - Bus:00H...
Try connecting your USB peripherals through a mains powered hub.
Dec 02, 2008 | Lenovo 3000 C200 Notebook
Computers & Internet Logo
David Payne
David Payne
