Question about Spark Plugs BR4HS Plug 10/BX #3322
Where is the outside air temp sensor on 1.8 vectra yr 2000
    Problem Solver:
  • 5 Answers
It's located near the vehicle's grille. behind the front bumper.
Posted on Oct 12, 2013
Radiator sensor holden vectra
For temp. gauge check the theremostat housing near the top hose enters the engine.
May 28, 2014 | Air Intake Hose Holden Vectra 2 Gts Hump...
My opel vectra 2000 is jerking, the engine is not moving smoothly and the brakes are making shrieking noise. Sometimes, when i slowed down in traffics or at checkpoints, the engines dies and i always have...
MAF sensor, the temp sensor is built into this and the problem is this, if you had the engine read on a op-com device you could of saved your self a lot of money and time. the air temp sensor or maf needs cleaning with MAF cleaner. only MAF cleaner, just had the same problem with in laws car and that was all it was. reading wrong air temp.
Jul 21, 2017 | Cars & Trucks
My outdoor air temp. reads -56 degrees when starting car, real air temp is 80, it keeps the a/c from turning on.
Hello, this is usually caused by a bad outside air temp sensor. the sensor is mounted behind the front grill, it has one connector with two wires pluged into it.
here is a picture of the sensor
Ambient Air Temperature Sensor Assembly
Jun 08, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
Location of temp sensor on 2000 blazer
The ambient temperature sensor for the mirror display or outside temerature, is located between the grill and air conditioning condenser. The coolant temperature sensor is located in the left (drivers) side cylinder head.
Mar 03, 2010 | 2000 Chevrolet Blazer
The message center shows incorrect outdoor temperature. It reads about 25 degrees higher than outside temp.
I would suspect that the connection to the outside temperature sensor is not good or the sensor itself is bad. Check the connection and clean and reattach as necessary. Otherwise replace the sensor. I think they're pretty reasonably priced.
The outside air temperature sensor for a 2000 Windstar is located under the front bumber on the passengers side. It is clearly visible if you lay down and look through the lower two air openings in the plastic bumper. It is the only electrical device in that area and it is made of black plastic.
Sep 22, 2009 | 2000 Ford Windstar
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Wireing tempature gauge
Outside temp sensor located at inner fairing, it is tied to left fairing frame just above cigarette lighter.
On OEM parts,
Air Temp Gauge pin#1 = Orange +12 Volt
Air Temp Gauge pin#2 = Black - ground
Air Temp Gauge pin#3 = Air Temp sensor pin#1
www.bengkelsepedamotor.wordpress.com
Dec 27, 2008 | 2005 Harley Davidson FLHTCUI Electra Glide...
Air conditioner blows hot
my 06 jetta did the thing. I fixed it by replacing the outside temp sensor. Turns out the air only works if temps are over 45 degrees. My outside temp sensor had gone bad. sensor was around $11.00 and I had to re-wwire it in because the original one had corroded. air has been working great sense.
Jul 26, 2008 | 2000 Volkswagen Jetta TDI
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
26 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
