Question about Blackburn Atom Sl 3.0
My sl 3.0 no longer picks up the signal from sensor so speed/ride time no longer work. I have changed all batteries and checked sensor area for mud/debris etc. the unit is less than twelve months old. The shop I bought from has since stopped trading so cannot return through normal channels. Thanks
    New Friend:
Its probably because the computer has lost the ID nuber. It happens every time when U change the batteries or re-setup the wheel size.
It happend with me and it took a long time to figure it out.
So try theese steps out:
1: check the ID number: (hold the right (mode) button for 5 seconds till "ID" is written on the screen) - if there is no number shown thats a good sign.
2. press the reset button on the remote (before make sure that the magnet is placed close enough and it is passes right true in the center of the battery cap of the remot) so RIGHT MAGNET POSITIONING IS ESENTIAL
3. after pressing RESET spin the wheel aproximatly for one minute.
If that is the problem it should pick up the sign.
Ps. A stronger magnet might also help.
Good luck.
Posted on Jan 13, 2014
  • Tibor Toader
    Tibor Toader Jan 13, 2014
    Good luck.
Beeping noise coming from glove box area. It beeps 3 times, slight pause then 2 or 3 more times. When I pick up speed for a few miles, it stops. C2 sensor????
Please tell us what vehicle you are working on. Does CEL come on? Does car have security system? Does this still happen if passenger is in car with seat belt fastened?
Jul 12, 2017 | Cars & Trucks
My car is not moveing, and it takes lots of fuel
That means you need the Oxygen Sensor, Knock sensor Camshaft position Sensor is usually on the outside of the timing cover which is a good thing. . Bank one simply means you are in front of your engine and you would pull the wire from the Number one spark plug and that part of your engine is bank one. The opposite side is bank two.
I would have the ECM (Engine Control Module ) checked. So many sensors going bad at the same time is just not normal. It's something that only a professional can do . Sorry about that. But to replace all those sensors one at a time would cost you not only money but a serious amount of time.
Oct 21, 2017 | 1997 Toyota Camry
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
P0715 changed both speed sensors 2002 hyundai elantra still have same code come up
I suspect that your transmission is slipping, you may not feel it yet but the sensors are picking it up in the relative speed signals from the input and output sensor.
Jun 17, 2012 | Cars & Trucks
My car Nissan 2.4 SE d/c year 2006, petrol, fuel injection has been giving me problems lately. a couple of years ago it started by smoking (black smoke), fuel consumption was too much, revs were...
Possible faults:-
Coolant sensor - engine is signaled as being 'cold' all the time, not just at start up, causing ECU to set longer injection cycle
? Low coolant level can prevent sensor being able to detect coolant temperature
? Faulty 'open' thermostat allows coolant to circulate without regulation and perhaps prevents the engine from achieving normal running temperatures.
To check put a voltmeter across the coolant sensor connections and there should be a difference between the engine being cold and hot. If not the sensor is faulty. Check sensor connections and wiring.
FPR - broken diaphragm allows fuel to enter the vacuum line and then into the inlet manifold. Additional source of fuel makes the fuel air mix richer causing a faster and lumpy idle. To check the FPR have the engine at idle and pull the vacuum line off it. If the FPR is healthy the engine will pick up in revs for a few seconds and then settle back to a very lumpy idle. If fuel dribbles out of the vacuum line then replace the FPR.
Vacuum leak - 'high oxygen' signal from O2 sensor causes ECU to set longer injection cycle. Check all hoses and connections with the inlet manifold. Check the inlet manifold to block junction and around injector ports. A small squirt of WD40 on suspect areas will cause the engine to momentarily pick up in revs if there is a leak.
O2 sensor - 'high oxygen' sensor error causes ECU to set longer fuel injection cycle. A voltmeter across the sensor pins should show above 200mV (note this is AC voltage). Check again when hot as the sensor can fail progressively and lose voltage as it gets hotter.
MAF - 'over reads' in error the amount of air entering causing ECU to set longer fuel injection cycle. Located in the collar next to the air filter box on the air ducting. Make sure the MAF is clean, do not touch, just spray it with electrical cleaner when it is off the car. The MAF has three wires (0volts; 5 volts supply; signal). Check that the signal voltage varies according to engine speed (air being sucked in). If not change it
IAT - 'under reads' in error the temperature of incoming air causing ECU to set longer fuel injection cycle. often co-located with the MAF but can be nearer the throttle on the air ducting. Has two wires. Unplug the IAT from the ducting and check that its resistance changes when you blow on it. Give it clean with electrical cleaner spray. If not change it
Hope the above check list helps.
Apr 12, 2011 | Nissan Hardbody Cars & Trucks
After changing batteries in both the outside sensor and the inside clock I no longer receive a reading for outside temp.
I have a thermometer with an outside sensor. It's necessary to remove both batteries, wait a few minutes, then replace batteries - sensor first. It may take a few minutes for the inside clock to pick up the signal. If it doesn't, try again with new batteries.
Dec 21, 2010 | SkyScan 86742 Digital Atomic Wall Clock
1994 GRAND MARQUIS Odometer stopped working, tridometer aswell
If the odometer and tripmeter stop incrementing their mile values, then the VSS or vehicle speed sensor is bad or has become disconnected.
Vehicle Speed Sensor OPERATION The Vehicle Speed Sensor (VSS) is a magnetic pick-up sensor that sends a signal to the Powertrain Control Module (PCM) and the speedometer. The sensor measures the rotation of the transmission output shaft or the ring gear on the differential and sends an AC voltage signal to the PCM which determines the corresponding vehicle speed.
TESTING
  1. Disconnect the negative battery cable.
  2. Disengage the wiring harness connector from the VSS.
  3. Using a Digital Volt-Ohmmeter (DVOM), measure the resistance (ohmmeter function) between the sensor terminals. If the resistance is 190-250 ohms, the sensor is okay.
REMOVAL & INSTALLATION Fig. 1: Detach the connector for the VSS sensor 91194p27.jpg
Fig. 2: Remove the retaining bolt for the VSS sensor and . . . 91194p28.jpg
Fig. 3: . . . remove the VSS sensor from the transmission 91194p29.jpg
Fig. 4: Pry the retainer for the VSS gear off and . . . 91194p30.jpg
Fig. 5: . . . remove the gear from the VSS 91194p31.jpg
  2. Raise and safely support the vehicle securely on jackstands.
  3. Detach the connector for the VSS.
  4. Remove the VSS retaining bolt and remove the VSS from the transmission.
  5. Remove the driven gear retainer and the drive gear. To install:
  6. Inspect the O-ring on the sensor and replace if necessary.
  7. Install the driven gear and the retainer.
  8. Place the VSS into the transmission.
  9. Tighten the retaining bolt to 98-115 inch lbs. (11-13 Nm).
  10. Attach the VSS electrical connector.
  11. Lower the vehicle.
  12. Connect the negative battery cable.
Oct 23, 2010 | 1994 Mercury Grand Marquis
1997 honda accord se need to change vss,where
For 1997 Honda Accord 2.2L MFI 4cyl the Vehicle Speed Sensor - Location is located mounted on transmission.
OPERATION
The Vehicle Speed Sensor (VSS) is a magnetic pick-up sensor that sends a signal to the Powertrain Control Module (PCM) and the speedometer. The sensor measures the rotation of the output shaft on the transaxle and sends an AC voltage signal to the PCM that determines the corresponding vehicle speed.
TESTING
  2. Disconnect the three terminal connector from the vehicle speed sensor (VSS).
  3. Remove the fasteners that secure the VSS to the transaxle housing assembly.
  4. Remove the VSS.
To install:
  1. Install the VSS.
  2. Install the mounting bolts.
  3. Connect the three terminal connector to the sensor.
  4. Connect the negative battery cable.
Hope helps (remember rated this).
Jul 16, 2010 | 1997 Honda Accord
1999 Saturn sl speed sensor
The vehicle speed sensor (VSS) is located in the differential area of the transaxle. Also, to replace it should be fairly simple. I wish I could give a better answer exactly where it is at, but I have you the answer straight out of the Haynes manual.
To replace the VSS, disconnect the electrical connector from the VSS. Then remove the retaining bolt and lift the VSS from the Transaxle or simply unscrew the VSS. Installation is the reverse of removal.
Feb 23, 2009 | 1999 Saturn SL
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
Blackburn Atom Sl 3.0 Logo
1,008 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Paris Johnson
Paris Johnson
Level 1 Expert
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
