Question about Car Audio & Video
Spl dynamics ext 3000d manual - Car Audio & Video
Need a spl z2x-1600 repair manual
SPLZ2X 1600 for Channel series to and how do I get the red light to come off and what is FET
Feb 28, 2012 | SPL Dynamics Z2X-1600 Car Audio Amplifier
I have an SPL Z1X 3000D Mono (3000W) amp that I just got so I could maximize my Sub's output. But My Kenwood 800W amp has better sound quality and is much louder. I don't know why
because a kenwood amp is true power and has better pertection built in it.the spl is a cheaper brand of equipment.just because it says 3000 whats doesnt mean it is,the spl is about 150 - 200 brand new,that should tell you why
Dec 12, 2010 | SPL Dynamics Z1X-3000D Car Audio Amplifier
I want to build a box for my kappa subs and i need to know what specs would make them sound great. they are goin in my 97 chevy ext cab truck. the box is going to be my back seat also
http://manuals.harman.com/INF/CAR/Boxes%20and%20Parameters/1001dvc.pdf
Not knowing your musical preference, take a look at this spec sheet and pick the sound you'd most like. The bandpass design usually gives the most SPL, but a larger box is probably deeper while still having good volume. Some audio purists say a sealed box sounds the best, subjectively, but the SPL isn't as great.
Nov 08, 2010 | Infinity KAPPA 100.1DVC Car Speaker
Amp goes straight to protecting
bad power supply or out put i hat to say it but spl is note a good company i would replace the amp
Jul 07, 2010 | SPL Dynamics CRM1200-2 Car Audio Amplifier
Why do the fuses in my amp keep blowing
You may not have they proper size wire to the amplifier. Most amps now recommend 4 ga. Also make sure your wiring to the speakers are at the proper Ohm load.
Dec 05, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
Power protec is signal red on
Missmatched impedence, ie you are running your amp which is 4ohm load to a sub which is 2ohm load, insufficient grounding could be the cause, blown transistor within the amp possibly.
Jul 30, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
What size fuses do i need
YOU CAN USUALLY GO WITH THE GREEN ONE 30.
May 02, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Spl car audio ampli ext-2000d no power comsuption
Read through the following page (particularly the section on troubleshooting a dead amp).
Amplifier Repair Primer
Let me know if you have any other questions.
Aug 09, 2008 | SPL Dynamics XL2-1600 Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
