I have a cozy mizer 16n, how do i use it, do i leave it on or switch it of once the coals are alight thanks
What is a coal scuttle
its a bucket you put coal in and the leave it at the side of your fire place.
Dec 09, 2016 | Grilling
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
Yamaha np 32 some keys faint in response
This is normally caused by dirty or worn contacts.
Simply open up the keyboard and replace the contact rubbers when the sensitivity has been lost.
There are 4 different rubber contacts depending on which notes are not working
WJ231101 RUBBER CONTACT 16N-2M OCT 2M-55
WJ231200 RUBBER CONTACT 16N-2M OCT 2M-45
WJ231301 RUBBER CONTACT 16N-2M 76H 2M-45
WJ231401 RUBBER CONTACT 16N-2M 76L 2M-55
Nov 12, 2016 | Yamaha Music
Coals are smouldering but they are not getting hot. getting a lot of smoke but temp not moving up. top and bottom vents are open all the way.
If you are rting to use the Egg as a grill instead of a smoker. The coals will heat up quickly if you raise the lid and leave it open. The way you were trying to do it is for smoking or baking not grilling. Leave the bottom vent open until the coals are really hot, then damper it down a little.
I hop this helped you and Happy Grilling. Thanks for choosing FixYa.
Jul 23, 2011 | Big Green Egg Grilling
The oven light on our FX5847 will not go out when the door is closed. I have manually pushed the switch when the door is open but it stay alight. Any ideas? Derek Tisdall
It sounds like the switch contacts are stuck together, If I were you, I would fit a new door switch.
Please leave feedback.
Thanks.
Nov 13, 2009 | De Dietrich Ovens
Strip between doors constantly hot
On some refrigerators there is a device which warms this area to prevent condensation as the cool air escapes from the compartments. you may have an energy mizer (or simular name) switch on the control panel. If found turn it off to see if this area cools. Temp should be warm to touch, but not hot. This only needs to run in the warm humid months, but is usually left on all year. If there is no switch, it is probably just the mizer, but if manual is available, best to check. No manual, most manufacturers have one available at their website.
Jul 05, 2009 | Refrigerators
Gas engineer wants to re-arrange coals correctly post service
yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Feb 05, 2009 | Cozy Heating & Cooling
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Transforming XP to Vista platform
Leave Vista Transformation Pack on it's place and use "Windows Vista Mizer". It is the best software to convert windows Xp into Vista you can convert to any edition of vista and also make bootable vista disc,
try this download link for Windows Vista mizer
http://www.softpedia.com/progDownload/VistaMizer-Download-74379.html
Oct 12, 2008 | Microsoft Windows Vista Ultimate Edition
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
