Question about LG Washing Machines
The machine is dispaying a P E code - LG Washing Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Water level malfunction
Posted on Nov 06, 2013
F21 code, what is it
Google make and error codes
Aug 14, 2017 | Washing Machines
Reset a brother MFC 7460DN after replacing the fuser unit?
You need to press Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press 88 then use the arrows to select Fuser and press ok. Then press 99
Oct 25, 2014 | Brother MFC 7460DN - Multifunction fax /...
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
While using the machine and during spin operation, the machine dispays the error message OE : drainage trouble, how can i fix this issue
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | LG Washing Machines
It dispays f1 then stops working
Primary Control Failure
F then 1 flashes when there is a primary control failure.
Replace the machine/motor control assembly.
TECH SHEET
Mar 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How to fix a code f25 kenmore elite he5 washer
F25 dispay comes on the washer stops. What is this and what can I do? Thanks, Ray
Nov 09, 2009 | Kenmore Washing Machines
F11
The F11 code is from a communication break in the serial link from the CCU to the MCU (from the brains to the washer motor controller). Stay with me here!
There are three blue wires that go to the MCU from the CCU. Most of the problems probably occur during the final spin when the machine spins fastest and longest to extract all of the water.
Hence, the most vibrations cause the connectors to shake until there is a break in communication!
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
E 60 ERROR
hiya
this code maybe down to the heater or something heater related on the pcb. i would replace the heater first as this is quite a common fault with zanussi from what i've found, and is not a very expensive part.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 12, 2008 | Zanussi ZWF1440 Front Load Washer
Machine shows Cl on dispay
cl is over loaded push stop clear to clear then try again with a lighter load
Jan 30, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
