Whirlpool dryer awz3477. light sensor is on - Washing Machines
2 Suggested Answers
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
Dryer wont turn on
We would suggest calling Whirlpool Customer Service in order to troubleshoot what could be happening with the dryer. Please contact us at 1-800-253-1301 and we would be happy to look into the dryer issue with you.
Aug 27, 2016 | Whirlpool Duet Steam WED9500TW 7.2 Cu. Ft....
Whirlpool awz3477
Sounds like you need a set of the T drivers to remove them. About $10 set at Sears. Also look closely and see if one or more of them have a small pin in center of the star. Many Manufactures use this as a security to keep the average DIY from fixing yourself. I got a set of 32 security bits at Harbor Freight for less than $5. You can use these with a 1/4 inch socket.
Another thing to check is the outlet from the dryer, This will require you to move the dryer out from the wall. Check the coiled hose for kinks or blocked at curves by lint. If you have not cleaned the dryer vent this year. While you have the dryer out from the wall, use an Electric leaf blower to blow out the dryer vent. If it is blocked it will cause the dryer to overheat and shut the heater down allowing the fan to run in an attempt to cool off.
Mar 23, 2014 | Dryers
Dryer sensor light blinking
press the End of Cycle button (hold down for 3 seconds, it should reset).
Oct 17, 2012 | Whirlpool GEW9200L Electric Dryer
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
The heat sensor is not working on my Whirlpool Gold. The hot setting has left burn marks on my husband's shirt. Should I get dryer repaired, or replace it?
repair. Have the venting system cleaned -to eliminate this out of the equation, After that, If your dryer is getting too hot after this, a sensor shuts off the circuit to light the gas (or heat the element-electric). It needs to be checked and may be bad.
Jul 02, 2009 | Whirlpool Dryers
Whirlpool cabrio steam electric dryer has sensor light on and does not work
Apr 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Whirlpool dryer
Go inside the dryer and get a wet rag. Clean the gookus off the sensors moted on the rear wall. 2 long skinny metal thinga majigs. If **** is on them they won't sense wetness. Also check the dryer vent for a blockage of lint. The fuse will blow but the console will still light up. 44813f6.jpg
Dec 15, 2008 | Dryers
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
I have a Whirlpool Gas Dryer LGV6848AWO.
the ignitor bar that lights the gas might not be coming on, the coils that open the gas valve in the dryer might not be opening the valve, or the flame sensor might be bad which would not allow power to the ignitor. these are the most common problems with whirlpool gas dryers
Nov 28, 2007 | Whirlpool LGR3624JQ Gas Dryer
Washing Machines Logo
Top Washing Machines Experts
