Question about Acer Aspire M1201 Athlon X2 320 Gb PC Desktop
I just installed a new motherboard and graphics card. I had this done at a tech shop, so they should know what they're doing... Anyway, the card is a ATI Radeon HD4650 PCIE 1024MB GDDR2. It's installed in an Acer desktop... Acer Aspire am1201-b1603a with 3gb ddr2 memory, 320 gb sata hard drive, etcetera, etcetera. I earlier learned that the motherboard in this computer was fried, so I had a new one installed at a tech shop. After a few days of exceptional-quality graphics, I now have an issue where when i surf the internet, my computer freezes completely and no keyboard commands work. I end up shutting it down by means of holding the power button in, then restart it. This happens all-too-frequently. No idea what to do with this unbelieveably problematic desktop computer anymore. (My power supply is big enough to support the card, by the way).
  • 2 more comments
  • dragon_obses Apr 23, 2009
    Windows was reinstalled and I recently updated the radeon video card driver.
  • dragon_obses Jul 27, 2009
    The drivers for the card are up to date. Windows was totally reinstalled.
    I will check the voltage on the wires you mentioned and get back to you. Sounds to me like a legitimate issue. Sounds like you know your stuff, too.
    I have a 500 watt supply, so it's got enough power. I also have a reliable anti-virus program installed, and have recently scanned my computer. The computer has no viruses.
    I also keep my running programs to a minimum, because I know that more programs running means more issues with this computer.
    Memory may be something to look in to. I'll have to check things out.
    Games aren't something that I constantly download off the internet. The only game that I have installed on my computer is World of Warcraft. I recently formatted the entire computer, and I make sure that I keep away from programs that I know I won't use, or that will clog my memory/resources.
    Oddly enough, when World of Warcraft is running in the background and I'm using the internet, the computer doesn't freeze. I have been using this as a solution.
  • 724 Answers
Well that is a new one. I always thought that the hardware of the computer drew the power from the supply and for the hardware to run properly the drivers do that trick on request. But the power rating of the supply will accomodate the drive motors are the ones that use the most wattage. Less than 300 watt supplies are the ones that will show you a flip flop...
Well since you surf the NET the bidg spider web... and you may have an anti virus program I guess go to trendmicro and use housecall it is a free scan just takes time this site is safe.
It really sounds to me that you have alot of programs running in the background that is using up resources and if you are using explorer 8 *ate Yes it is a realestate hog it eat memory that is your resources CTRL-ALT-DEL task manager tap into performance tab PF usage should be lower than then 0.5 of your total memory 3/4 usage is a red area! This usage is a gauge for your resources.
You may have to increase your memory or reduse whart is running or sitting in standby...
The memory today is less expensive than in the early years.
I expect you have went hog wild trying new things on the net installing games and never uninstalling them and they may be sitting in standby mode in your memory which is eating your resources.
If you card ran good for a week and suddenly you are experiencing poor running performance and the images are great as they where after the video install. Yea they know what they are doing and you are just learning this! Otherwise you would of did your own work...
Posted on Jul 27, 2009
  • tommya300
    tommya300 Jul 28, 2009
    You use a game program as a solution? Then the solution is the relation! I worked on computers since the late 88 and never had seen using a running game program to be the solution, I have no other way but to believe you, it was always the removal. Programs can occupy and run in the back ground undetected, the hackers ultimate goal, not saying that is the thing. Your game relies on connecting to the net? Well I question that game just by your descriptions.
    Reliable anti virus (name it) please, you did not check the memory usage in the task manager???? The effort is so small in comparing writing back saying you did not look... Seeing this will tell you, you are running at minimun, not assuming on the users part. Not a constant but you do download games ???
    One thing after you had reformated you HD, or whole machine that is, did you have a problem right after that? Did it run great until you installed something like the ( problem/solution)...
    Well it that game is the solution save face it might be the responsable item! I never heard of any over powered power supply giving a problem such as ... It was alway that when the load overwhelmed the power source a shutdown or a blackout happened.
    In the 20 years on repairs and I seem a mass of computer problems. After 8 years the problems were just repeated same ones over and over. Solutions become, yep, I seen that before type thing. One or two were new discoveries but in most part a 98% are in archive form! Now I do not know much of Vista it is new and might have a load of new items that are problems.
  • tommya300
    I have an old AMI 750 MHz when they first came out in the late 90s
    3/4 gig memory maxed
    an old Creative DXR2 DVD player which needs an PCI DVD configuration card read DVDs only this was back in the days that DVD players just cropped up
    an ISA scuzzy card for my old HP scanner
    a PCI Creative sound card
    Network card
    a video capture card Pinnacle with firewire external plugs
    3 CPU fans
    2 maxtor internal Harddrives
    1 maxtor tera byte external usb / firewire using firewire external AC adaptor
    2 usb ports
    one has a wireless mouse
    the other has an extendes port 7 extra and they are all filled some used and some are standby.
    An internal CD player
    1 floppy drive
    350 Watt power supply runnning the whole computer
    I had to replace the supply once last year It finally broke down like a light bulb.
    Other than that the machine never had a related Power supply problem.
    Yea I had to reformat yea it did get slugish yea I found viruses yea I found programs running, yea I had memory leaks any certified programmer know what that is, I also discovered that the best is Trend Micro. Nortons and then non!
    Micro trend has a free housecall at their site FREE and they have to be reliable their future is Anti Virus no fly by nite organization.
    So what I am saying if this is academic and they are documenting this about the supply the problem is questionablly related I have an electronic's 2 year degree and 8 years in that feeled 20 years of computer experience and never was certified but when I hear real people that I have a face to face tell me that they brought their machines here and there and they were not satisfied..
    They ask what did I do different to fix it! I do not know because I have no idea what the other guy done...
    Also in IE 7 or higher
    go into tools
    internet options
    delete
    delete all
    delete add on files, check box checked
    OK
    Then check where the cookies are stored make sure that folder is flushed...
    Sergeant:
    Novelist:
  • 192 Answers
I understand that your power supply may be large enough, but there is a problem with it.
When you use any system, the base power supply is about 350 Watts. However, for every two drives you add to the system, add about 50 Watts. PCI cards about 20 Watts.
I suspect that if your system is freezing all of the time, check the voltages on the +12 V yellow, -12 V blue, and the red, and white wires.
When the voltage difference from positive and negative voltage exceed .4 watts difference, then the computer starts freezing. I've tested over 100 power supplies.
Any other questions, I am a certified A+, Network+, and Server+ technician. Studying for my Linux+ certification.
Posted on Jul 25, 2009
  • dbucyk Jul 27, 2009
    Did you have the power supply checked on all voltages? If the discrepancy is large enough between the positive and negative voltages, that would explain your problem.
    P.S.: Do you have the manual that came with your acer aspire am1201-b1603a? If you do, would you be willing to email me a copy of the manual?
  • 123 Answers
Sounds like some kind of conflict. Make sure you have the latest video drivers for your OS. Was the os reinstalled after the new motherboard put in? This could cause problems if you actually managed to get windows running without reinstalling.
Posted on Apr 23, 2009
  • Fritzelly Apr 23, 2009
    Do you have any ATI software running controlling the card, if so try removing this so you are only using the driver. If still no joy restart in safe mode and see if the problem persists so we can rule out other problems.
I want to upgrade my graphics card, i currently have a Nvidia Geforce 7300 LE installed, which is 128 mb. Which new grapihic card can i install in my motherboard?
Hello here is the homepage for your mainboard:
http://www.asus.com/Motherboards/P5GCMX1333/#specifications
Your mainboard is using the PCI-E 16 socket.
This is great because all new graphic card has this socket.
I would choose a AMD graphic card, 1 to 2 gb in the 6000 series.
Price is around 100 to 200 dollars.
But some of them will need external power from the power supply
as they need 100 to 200 watts, depending how much money you will spend.
You will maybe also need a new power supply for at least 500 watts.
A local computer dealer or online shop can sell you a great graphic card.
Please uninstall all old nvidia graphic software, before installing the new graphic software.
Good luck
Sep 15, 2013 | ASUS P5GC-MX/1333 Motherboard
Myn mother board is amd i will play games but some games would ask for graphic card but i hesitate to use it is there anyway to play games with out using graphic card
Some games will work fine with the on-board graphics card, but the newer and/or more powerful games require a more powerful graphics card. These will not run unless you install a good graphics card in your machine. Sorry.
Jul 24, 2011 | Mercury P4VM800M7 Motherboard
NEED TO CHANGE MY BIOS SO MY NEW GRAPHICS CARD WILL LOAD INSTEAD OF THE ONBOARD ONE BUT I DONT KNOW WHICH SETTING TO CHANG
Hello
In that way no need to change the BIOS settings, you can install a new graphics card directly. Once you are already installed the new graphics card you need to install also the driver so that it will work properly. Connect your monitor cord to the new installed graphics card. Now you can enjoy using your computer with the new installed graphics card.
Regards
PCmania
Sep 25, 2009 | Intel Microstar MS-6526 Pentium 4 ATX...
I get no video and the monitor is good. Need to
IT doesnt matter. If the Video Card is built into the Motherboard and has failed; you can get NEW Card that can plug into an Expansion Port on *********** board
Make sure your motherboard is compatible with the NEW video card. For example, PCI Express video cards won't work with motherboards designed only for AGP or PCI video cards, and vice versa. Tigerdirect.com has a good selection. Call their Customer Service Tech; they have great prices, sales and knowlegable Customre Service Tech to Check if it is the right Type of Card. Its probably PCI but check anyway.
Simply shut down unplug and open the computer side panel and go to the back of the Machine. If there is a separate Card (it will be obvious as it has a VGA port) Remove it and just install your new card in its place and plug in your Monitor to the new VGA port. If not then just POP OUT A FREE SLOT in the back of your Computer next to the Plug In Port so the VGA port that the monitor plugs into stick out the back and plug in your Monitor.
Close , plug in and INSTALL THE SOFTWARE THAT COMES WITH THE VIDEO CARD. Set all settings to DEFAULT or be creative :)
Cheers !
Aug 21, 2009 | HP Pavilion a1253w Notebook
I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
Jul 19, 2009 | ASUS GeForce 6200 TC, TD64 Video Card
HP motherboard dangling sounds when powered on
f you switched monitors already, your graphics card is probably the problem. I would suggest to temporarily switch this graphics card with another one. Maybe you can do that yousef, or know someone who can. Do nt try this without knowing what you're doing, it could damage your graphics card.
If you have done this, or are unable too, please post here what happened.
If the results you get with the other graphics card are:
1. You do get signal, but it is very low resolution. This is what is supposed to happen. It means you do get a good signal, the video drivers for that card just aren't installed yet. I'm afraid your graphics card is broken, and that you're going to need a new one.
2. You still don't get signal. This could be two things. Either your VGA cable is broken, or your motherboard is broken. I would suggest trying another ble. If that still doesn't work, you will have to purchase another motherboard.
I hope this helps,
Yannick.
May 18, 2009 | HP (5064-6630) Motherboard
I have a enbuild graphics card i cant play games . while installing it does not support.It shows error
Many of the onboard graphics solutions are not able to handle a majority of the popular games on the market today. Motherboard manufactures know this and so don't put too much thought into upgrading the onboard solutions, being that a great majority of avid gamers would by a graphics card anyway.
My first thought is to buy yourself a graphics card. You probably wont need anything overly special (although I am not sure of how much you may play games) but for decent beginner cards, they run you anywhere from $20-$80 these days. For a little more say ~$100, you can get yourself a decent card that can play most games on the market today. However, do take in mind what your motherboard can actually handle as far as slots go (PCI, AGP, PCI-E).
Apr 22, 2009 | HP Computers & Internet
Monitor screen freeze with driver...
hi! you don't need to update the driver cause the problem is in your hardware. Graphic seems to be a bit grounded, try cleaning the contact pins of your AGP graphic card with eraser, clean it side by side and then put it back again to an AGP slot, then boot your CPU again. If it still the same, try it in another motherboard that support you graphic card just to be sure before we conclude that its the graphic card has the problem. Anyway if it still under warranty you can claim for a replacement to the store where you bought the graphic card.  Have a nice day!
Dec 28, 2008 | ATI RADEON X1650 Graphic Card
Help plse
I' m not sure but i think that you can do it. Ask in shop.
Nov 24, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Lost internet connection - after installing graphic card
If this is the power problem then change your SMPS with more Wats power.
Jun 09, 2008 | VIA P4MA Motherboard
Acer Aspire M1201 Athlon X2 320 Gb  PC Desktop Logo
428 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
