Question about RCA RCU1010 LCD Touchscreen Remote Control
When I change the batteries on my RCU-1010 the bottom row of buttons quit working. How do I get them reactivated?
  • john_o_jacob Apr 23, 2009
    Yes, the bottom row keys was working before I changed the batteries.
  • 68 Answers
Were they working before????? if not then it is faulty
Posted on Apr 23, 2009
I have a Hampton Bay ceiling fan with remote. Only the fan works on HIGH. How do you reset remote so it works on all settings? The says set F/C on the back with fcc ID:CHQ8BT7096T. On the front from top to...
Seems like the remote doesn't work. Change the batteries. Verify the switch settings in the battery compartment match the setting of the switches on the very top of the fan itself. dd4540b.jpg
Sep 02, 2010 | Heating & Cooling
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
Mouse just quit working, installed new batteries red light works
Normal 0 Make sure that the batteries are good then do the following.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 07, 2009 | Logitech Cordless Mouse
Changing the language
Turn on your machine. The SET tab is the fifth from the left (or second from the right). Touch that.
You now need to touch the More button, which is on the bottom row and is the button on the left hand side (there are two buttons at the bottom - More and OK).
On the next page that comes up, the LANGUAGE select button is the single orange button at the bottom of the list. The two buttons at the very bottom are once again More and OK, so go above them to the single orange button. Each time you press this, the language changes. There are quite a lot to scroll through, but keep pushing it until English comes up again.
That should fix your machine for you. No suggestions on how to fix your husband, though!
Pamsquilt
Oct 16, 2008 | Husqvarna Designer I
Change the picture size on an aurex tv using the buttons on the side of tv
I too have an Aurex TV ..and have to adjust the screen size regularly .I do this by the hand control.at the bottom of the handset are two rows of buttons..3 on the bottom row and 4 on the next row up..the on furthest on the right on the row with 4 buttons is the button for screen size change.
Oct 09, 2008 | Televison & Video
Cordless Mouse Just quit working While In Use
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Sep 07, 2008 | Logitech Cordless Mouse
Rcu 450
The book says the following should work for JVC TVs 012 013 054 060 065 066 067 123 157 158 159 182
Apr 20, 2008 | Televison & Video
I need programming procedure for RCA remote control rcu-100, along with the codes for sharp TV 13l-m100.
hit component button (tv. vcr1, vcr2, cable , or audio. you'd hit tv) then ID button. within 3 seconds, enter two digit code and test with on/off button.
sharp has quite a few codes. if first doesn't work, move to next code.
11,20,25,27,37,52,53,59,60
Jan 10, 2008 | Televison & Video
RCU 1010 BACKLIGHT
I would check/replace the batteries. The backlight draws alot more power than the rest of the unit. The other functions could work but no backlight with weak batteries.
Dec 01, 2005 | RCA RCU1010 LCD Touchscreen Remote Control
RCA RCU1010 LCD Touchscreen Remote Control Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
