Question about Dishwashers
My dishwasher is an Omega DW402XA and it just keeps stopping after 2 min and beeping about 20 times
SOURCE: Tecnik dishwasher keeps on washing... and washing!
the "programer" has gone
Posted on Dec 11, 2008
buffalonyman
  • 1865 Answers
SOURCE: My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
Posted on May 02, 2009
SOURCE: whirlpool dishwasher
I can't guarantee to solve this but we had flashingh light problem and in the end all I did was to set the dial to the wash I wanted and kept my finger on the start button for about 10 to 20 seconds and it suddenly woke up and started. It had obviouosy had a hard day and wanted a rest
good luck
Martin
Posted on Jul 02, 2009
  • 6 Answers
SOURCE: cda cw494 dishwasher it runs for about 20 mins
is the light indicator flashing because you need to add salt or rinse aid.i have a bosch and my lights only flash to give me information on addig salt and,or rinse aid. so i can stop this by setting my dishwasher to take all in one detergent ,then the lights will not flash.
Posted on Nov 10, 2009
GodBlessU
  • 3513 Answers
SOURCE: I have F&P DD603 with
Hi
When you pull out the drawer, pay attention to the bottom near the bottom front panel, you will see a little tab. this tab is at both sides of the drawer, press these tabs in and pull the drawer further a bit, you can see the tub move out a little further. Now lift the tube up and out ot the rails. Push the rail inside the dishwasher, then you will be able to put the drawer down on the floor. Don't try to pull the tube out so much since hoses are under the tube has a limited length.
This dishwasher has a diagnostics mode which can be entered but you need the service manual which is attached to the back wall inside the cavity ( you can see it if you pull the drawer all the way out but you cant reach it without removing the drawer from its roller guides.) You can enter the diagnostics mode by pushing keylock,and holding it in. Then push and hold start/pause in that order. If you push start pause first it just counts through a delay start.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 31, 2010
Why does my Electrolux dishwasher keep beeping 20 continuously?
call electrolux i cant find anything that is free,they all want money
May 09, 2015 | Electrolux Dishwashers
What's causing my dishwasher to stop in the cleaning cycle, and how do i fix?
It's probably the switch that is attached to the latch. Could also be the latch itself or the strike.
Sep 25, 2014 | Whirlpool Dishwashers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Top drawer stops, will restart if I push start
Sounds like a micro switch problem to me, telling the dishwasher that the drawer is open when it is not actually open.
Dec 26, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
219 people viewed this question
Top Dishwashers Experts
