Question about Siemens Washing Machines
F21 problem on f1046 washing machine - Siemens Washing Machines
I have F21 on my machine, how can I fix it?
The F21 error is generally related to the drain of the washing machine (depending on the brand of your machine). Basically it means that the drain is clogged and the machine is taking too long to empty the water out.
Cleaning the drain is not for the queasy. You can find information on how to clean out the drain by visiting: http://www.kiwiservices.com/angela-says/fix-an-f21-code/
Apr 07, 2017 | Washing Machines
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Have a code F21--What is wrong and how do I fix it?
This site has a good solution, assuming this is your brand name of machine... but the solution might apply to you otherwise:
http://www.managemylife.com/mmh/questions/230239-front-loader-washing-machine-whirlpool-duet-broken-says-f21
Oct 18, 2013 | Washing Machines
How can I reset alarm F21 on Bosch washing machine type WIM40?
Dear Sir,
it is requested you that we have a washing machine Type: WIM40 & RN # WAE20463tr/12 it has still showing error on display as "F21 alaram" Kindly resolve it or tell us solution that what will be.
Best Regards,
Imran Khan Nawab
May 13, 2012 | Bosch Washing Machines
I have a amana washing machine model #nfw7500vw and I get a failure code f21 whats the problem
F21 Long drain Possible cause: Clogged filter, clogged/failed pumpthemobilian_200.jpg
By the way your tech sheet will give you the codes and what to do.
Nov 19, 2010 | Amana Washing Machines
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
