Rc plus programmable room thermostat model rf316 2f22560 user guide
How do you set the on off time
tborn6
  • 700 Answers
SOURCE: alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Posted on Jan 07, 2009
frcs68
  • 1605 Answers
SOURCE: I need user's manual for Danfoss Randall Thermostat TP4000
go to the following link.
download and print the user namual.
http://randall.danfoss.com/PCMPDF/40811v01.pdf
Posted on Apr 06, 2009
  • 1015 Answers
SOURCE: Honeywell RTH 221 Programmable Thermostat. Jumper missing
The proper way to do it would be to use a small piece of wire stripped at the ends. Then use a small amount fo solder on each end to connect RC to RH. Or use a small piece of solid(stiff) wire and strip the ends. The wrap the ends around the connector and crimp them to make contact. I would not use a paper clip. A paper clip is not designed to carry 24volt current and could melt.
Posted on Nov 02, 2009
SOURCE: I HAVE A HONEYWELL T8600D
pknab, I have the same problem. And it comes down a few things: 1) the flashing 1:00 indicates that you've lost power, and the system needs to be reset. 2) Reset means taking out the batteries for longer than 5 minutes. 3) You have to change your filter monthly. There's one in the cold air return and another one in the furnace. If you don't, your FURNACE may be causing number one (my conjecture). 4) We had an electrical storm 2 days ago--nothing else in the house lost its sense of time...but...well...the online operating manual is difficult to find try http://customer.honeywell.com/techlit/pdf/69-0000s/69-1400.pdf or http://dl.owneriq.net/e/e67c2c91-73c2-4bd8-abc8-91d843a27658.pdf (but it doesn't tell us this stuff...I'm still looking for the meaning of the EEE in the display..perhaps I have repowered the thermostat/furnace in the wrong order).
Posted on Dec 16, 2010
hvac1960
  • 2133 Answers
SOURCE: User Guide for Garrison Programmable
Please try with :
x-msg.net/related.../garrison-programmable-7-day-thermostat-user-guide.html
Posted on Dec 30, 2010
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
How do I wire a Honeywell room thermostat T6360B1028?
The red goes to R or rc and the blue would go to C or common sometimes its BK on the thermostat and the yellow would go to Y.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
I have just installed underfloor heating with 4 zones. I also have the existing radiator system. The radiator system is currently programmed to come on and off twice a day but has no room thermostat. We...
You say you have3 rooms on the underfloor system that will probably require different temps. You said you have 1 zone valve for the under floor system. You can not control all the rooms with different thermostats and only 1 zone valve. You need more information and professional help here. I can give you more advice too...
Jun 22, 2009 | Honeywell Programmable Thermostat Heater
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
Aug 26, 2008 | Honeywell Programmable Thermostat Heater
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
