Question about Food Mixers
AEG Assistant all in one Type FP610 need a hand book
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 | Food Mixers
How does work the motor ? with dc 24 volts or ac voltage
if it has a cord attached it is 115 if not it could be 12 volt or 24volt
Sep 03, 2016 | Braun M880 MultiMix Hand Mixer
How can i fix this problem
PDF]SM-70 INSTRUCTION BOOKLET 7.0 Quart Stand ... - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/sm-70.pdf
Cuisinart7. Do not exceed the maximum capacities listed in this use and care instruction book. 8. ... Troubleshooting . ... extra-large Cuisinart™ 7 Quart Stand Mixer.
Jul 30, 2015 | Cuisinart 7 Quart Stand Mixer
My bamix attachments keep falling off, tried tightning them as per instruction book to no avail.
II had the same problem but I just kept adjusting it and make sure it fits into the notch, and it works. It a bit annoying, but persevere.
Best wishes
Jan 15, 2012 | Bamix De Luxe Hand Mixer
Braun Vario 280 Watt type 480 hand held blender. The bowl top that the hand mixer fitsd into is frozen. The hand held motor works but the shaft in the top that turns the blade is frozen. I don't...
HI.This steps might be as well helpful.let me just clarify that you can't even manually twist the shafting.If the motor is working an yet it will not turn the shaft.Tha shafting bossing might as well been broken misallign inside..Better remove the cover by unscrewing it and then try to observe how the motor works.If it really does turn when ever it is plugg on to the source.Observe also misallign bosssing that connects the shafting and the motor's rotor.Thank you for choosing FIXYA.
Aug 16, 2011 | Braun M880 MultiMix Hand Mixer
Necesito un recambio para un multimix braum m880. ¿cómo lo puedo pedir? gracias. mi email: fanyclarinet@hotmail.com
According to my limited spanish I assume you need spare parts?
I suggest braun.com internationally, and also smallappliance.com if you live in the US.
You will find the 4-digit type number required on the base plate.
Feb 17, 2010 | Braun M880 MultiMix Hand Mixer
12c 150 watt missing front dial
type in the manufacturer in the search bar and sometimes you can find the history leading to the current ,anufacturer and service centers. Good Luck
Sep 21, 2009 | Sunbeam 2485 MixMaster Series Hand Mixer
Food Mixers Logo
295 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
