How do I change the time on VISLED3260HD? The clock on time menu won't highlight!
Clock has wrong time unable to change
Wrong Time Or Clock Not Set
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsAug 3, 2010 - Features ? > Clock ? > Wrong Time Or Clock Not Set Share on Google+ ... of which receive RF transmissions, you cannot use the Auto Clock Set. ... Press the ? or ? to change the value of the highlighted field and press ... If after reading through the previous troubleshooting steps you still have questions, ...
iPhone/iPad Has Wrong Timezone When Date/Time is Set
Dec 28, 2015 | Audio Players & Recorders
Setting the clock
HI,
Please give me a min.i'll let you know if there's a manual available for your model
Apr 24, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Clock is one hour fast
To change the clock time, just right click on the clock in the bottom right. Then go to Adjust Date/Time. A window should open and there should be an option to Change Date/Time. Click on that and a new window opens up. On the right of that window is the clock. Just click on the hour to highlight it and then click the down arrow to put it down one hour. Press ok and your clock is fixed.
Thanks for using FixYa!
May 19, 2011 | Computers & Internet
Have never set date on my camera. What do I need to do to accomplish this? Do I needsoft ware, any cords, etc? Tried to go by instructions on line but it didn't work. What am I missing? Thanks
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
Mar 23, 2011 | Kodak EasyShare CX7330 Digital Camera
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
HOW DO YOU SET AN ALARM? CAN YOU SET MULTIPLE ALARMS?
Hi, To turn on the alarm function in the Clock application on the BlackBerry smartphone, complete the following steps: In the Clock application, press the Menu key. Click Set Alarm. Set the alarm time by highlighting the hour, minute, and 12-hour notation fields and rolling the trackball. Highlight the text beside the alarm time. Roll the trackball and select either ON (everyday) or WEEKDAYS (weekdays only). Press the Escape key. An alarm indicator appears in the bottom left corner of the Clock application. To set alarm notification options To set the alarm notification options, complete the following steps: In the Clock application, press the Menu key. Click Options. In the Alarm section, choose an option for the Alert Type, Alarm Tune, Volume, Snooze Time, and Number of Vibrations fields. Press the Menu key. Click Save.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 11, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Lost my manual and cant figure out how to set the time. Any help out there. Thank you
From the user's manual
Setting the Clock
1 Turn the Mode control until the clock icon is highlighted
with brackets .
2 Press the Mode control. The clock icon and time display will
flash.
3 Turn the Mode control to adjust the time.
4 Press the Mode control again to set the time. The display
reverts to its previous mode and the new time is set.
Note: The clock can display time in either 12 hour or 24 hour
format. To change the time display turn the mode control to
highlight the clock icon with brackets . Press and hold the mode
control for 5 seconds. The display will show “12H” or “24H”. Turn the
mode control to select the time format you want, then press the
control.
Mar 08, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Setting of time dsc h5
First Press the MENU BUTTON:
Now you will see: Setup>
Use the directional buttons (big round button) on your camera to navigate throught the menus .
RIGHT ARROW PULLS UP > CAMERA 1 MENU and you will have a yellow highlite on the left side.
use the down arrow to select and highlite>SETUP FOLDER #2,
When you have that highlighted push the > RIGHT ARROW to move the HIGHLITE to the next selection.
>USE THE DOWN ARROW and highlite> CLOCK SET > when that is yellow>use the right arrow to get into it and select> OK PRESS ENTER (the little round button inside the arrow buttons.
AND YOU ARE IN THE CLOCK/DATE/TIME SETUP MODE MAKE YOUR CHANGES AND SELECT OK and press the enter button and you are done. Just press the Menu button to exit the menue
Aug 13, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
