Question about Proform 790T Treadmill
Hello I have a Pro Form 790t. It turns on ok but when I hit the start button the belt does not move. I've had an electrician check it and everything is ok. Someone mentioned about lubricating it but I don't know how or if this is the problem. Please can you help? Many thanks Karen
moel64
  • 18 Answers
SOURCE: Pro-Form 360P, when I step on the belt, it stops
when the belt is stopped you should be check the deck if this it´s worm or the walking belt, because a probable cause is lack of lubrication, In addition should send the engine to revision, because according to what your gross probably already there are some Diode Rectifier damaged, You must know that the cause that generates this problem stems from the walking belt and the table or deck
Posted on Jul 17, 2009
SOURCE: we need a new control board for our pro-form 560
yes sounds like a contoller, if you need to order contact us through the web at www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
SOURCE: Pro Form treadmill display lights up but the
Check out The treadmill Doc. Fantastic site and great people to do business with. A lot of helpful trouble shooting information for free! I'm betting it is the motor control board. Site will lead you through step by step instructions to check and fix it yourself. I saved a ton of money and with a little know how and good information you can too.
Posted on Dec 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
  • 48 Answers
SOURCE: I have an pro form trademills showing an E1 error
motor brushes are bad that is why motor can not start itself
Posted on Nov 25, 2010
Slipped belt
there are two bolts on the rear of treadmill walking deck. these are adjustment bolts. start with the belt going 3mph. tighten the side where the belt is closest.only go 1/4 turn at a time.give it 15-20 seconds for belt to track or move over. continue until centered.
Apr 17, 2014 | Proform Pro-Form 520 ZN Treadmill
Assembled my ProForm 790T yesterday. I am using it with a TrekDesk so only ran it at 1mph and no incline yesterday. Worked fine. I noticed the belt was slightly over to one side, so I made a 1/4 turn...
DEAR
IF YOU DO NOT ANY MOVE YOUR MOTOR CONTROL BOARD IS DAMAGE
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 18, 2017 | Proform 790T Treadmill
Pro form 995 motor won't turn on
Dear Sir:
You must do the following:
1) You must check the receptacle wall, for 115volts AC,60hz
2) If Not voltage 115 Vac, check breaker or fuse from the Panel( Main) or Sub-Panel for that circuit.
3) If there are 115 Vac, so proceed with the wires of the plugs, retigh conection and see if the contact of the plug is clean or oxide, ( clean with ethilic alcohol 100%) .
4) Check the Main button if there Voltage use the VOM( Voltimeter) , after check the push button Start , clean this .
5) If not work, check the relais and clean with ethilic alcohol 100% in the Board Controller, after check the Breaker.
6) If everything is o.k now proceed to Start the Motor.
7) In short proceed Step by Step with the logic for Troubleshooting.
Please reply is everything is o.k or you need more assistance, Sincerely . God bless you.
E. Cuadra
Sep 05, 2011 | Proform Exercise & Fitness
My pro form treadmill - panel lights come on but belt not operating? Any ideas how to repair or who would call out - Derbyshire area? Thanks
If the light are on and when pushing the console start button the oval track lights (on the console) should move. If not, then your console is bad. On most Pro Form consoles you have to replace the entire console. Individual parts are not available.
Jul 28, 2010 | Proform Exercise & Fitness
Blinking alarm light won't go off and printer inop. Power off and all check made, disconnected from compomputer. Went inop right after printing. In cartridridges and cassette moves freely and everything...
Please try this step to turn off your alarm light.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | Canon PIXMA MP750 All-In-One InkJet...
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Lights work and unit clicks when u hit the start button but the motor will not run. checked thermal fuse and it checked out to be ok.
it may have a belt switch(check belt) or you have lint in the motor switch and the switch lever can't move compressed air works best to clean it
Aug 25, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Monitor will not turn on
My LG L19534H (analog) flat panel monitor began doing this too after two years of good performance in a Windows XP Pro environment. Here is my crude "fix": right-click desktop, hit Properties, select Screen Saver tab, hit Power button, and choose "Never" from the drop down lists for Monitor and System Standby. Hit OK to save changes. Yes...you're right...what if you need standby, etc. Don't know if it's video card starting to fail or not. Time will tell. Hope this helps for now.
Apr 04, 2009 | Dell E228WFP LCD Monitor
TT 02 doesn't spin - Help!
i don't know if these are belt driven or not but i would check to see if the belt fell off, if motor driven then i would suspect a bad motor.
Dec 31, 2007 | Philips gemini TT-02 Turntable
Proform 790T Treadmill Logo
32 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
