Sc 863 ricoh 2035 - Office Equipment & Supplies
SOURCE: I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Posted on Jun 26, 2009
  • 11 Answers
SOURCE: I have a ricoh aficio 2035 that reads error sc 546
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Posted on Aug 17, 2009
socalern
  • 48 Answers
SOURCE: my Ricoh Aficio copier 2051 the problem is SC
SC 863 indicates that there are bad sectors in your machines hard drive. You have two options. First, try to have your hard drive re-formatted (you do this through the control panel in the service mode) but beware, any documents stored in the document server will be deleted and so will the scan to folder pre-programmed in the machine.
Second option, assuming the re-formatting did not work, would be replacing the hard drive altogether
Hdd formatting procedures:
service mode entry: press clear modes, press 107 then hold down the clear stop red button for 10 seconds, screen will then change. select copier, then upper right side select "sp direct" then punch in 5832.
Execute 5832 001 to format the HDD.
Posted on Jan 16, 2010
  • 161 Answers
Bad hard disk, try formating it or replace it
Posted on Jan 17, 2010
Testimonial: "tanks."
  • 126 Answers
SOURCE: ricoh aficio 2035 sc 322
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Posted on Oct 01, 2010
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
IN RICOH AF 2045 SC 990
This error code could be related to a Physical problem (machine) or Network Problem.
Physical problem:
Try to clean the ID sensor.
Probably you will also need to clean or replace the Drum Unit.
Network problem:
Upgrade your firmware.
(If you do not have technical skills a advise you to call your provider)
See you!
Jun 06, 2011 | Ricoh Aficio 2035 Copier
Td sensor setting problem ricoh 2035
i think you are facing the problem with SC-390 while initialization,The TD sensor output voltage is less than 0.5V or more than 5.0V after 10 consecutive times during copying. that meens TD sensor defective or Developer failure or IOB bord faiure if you are not a tech. person please call the right person to fix this problem
thankyou
Dec 16, 2010 | Ricoh Aficio 2035 Copier
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
Sep 28, 2010 | Ricoh Aficio 450 Copier
Sc 990 ERROR PROBLEM ON RICOH 2045/2035. how can i solve this problem..
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Sep 14, 2010 | Ricoh Office Equipment & Supplies
My Ricoh Aficio copier 2051 the problem is SC 863-13 can u solve it?
Jan 15, 2010 | Ricoh Office Equipment & Supplies
Jun 25, 2009 | Ricoh Aficio 450 Copier
118 people viewed this question
jasbo
jasbo
