Question about Whirlpool RBD305PD Electric Double Oven
Whirlpool code E6 displays when turn on model AKM 990
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: RBD305 Whirlpool wall Oven Beeped
You have a shorted control pad you need to replace it.
Posted on Jan 11, 2009
localwonder
  • 6784 Answers
SOURCE: My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Aug 08, 2009
fixyourboard
  • 310 Answers
SOURCE: whirlpool accubake system model#RBD275PDS15 has
This could be either a problem with the keypad or the control. Here's the manufacturer's "recommended repair procedure":
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control.
... not so good, they want you to replace the keypad and if that doesn't work replace the control board ... both very expensive!
First I suggest trying to clean up the keypad ribbon connection into the control board ... this is free! We put a procedure on our website that describes how to do it, heres the link:
http://www.fixyourboard.com/techzone/ovens/keypad_tail_clean/keypad_tail_clean.html
If you come to the conclusion that the failure is due to the control board, we can have a look at it for you if your comfortable to remove it. We repair oven controllers.
Or, if you want to send us the keypad and control board as a unit (they are bolted together) we can determine which is the problem and repair as needed.
Best Regards,
Bruce
Posted on Oct 03, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool double oven rbd306pdb15 displaying
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Posted on Aug 23, 2010
Testimonial: "Thank you. We will let you know how that goes if we can find the "how to" on that repair."
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Model RBD245PDB14 Error code F2 E6(left side) replaced original key pad with new. One week after install same error code and display blank out. Unpluged and reattached key pad cable but still diplays F2 E6...
If you replace the keypad and continue to have the same error you also have to replace the electronic control.
You can contact fixyourboard. com for a price to repair your control at a reduced price over a new control. It also comes back with a better warranty than anew control.
Jan 03, 2010 | Whirlpool Ovens
Whirlpool oven model RBD275PDT12 display showing error code E6 F2 after display out for 12 hours. My daughter was cooking Friday night. She said she saw the display say ''end''. On saturday morning display...
We see this error very frequently at www.fixyourboard.com. It is sometime accompanied by a display that goes blank. The boards can be fixed quickly, reliably and with a long warranty.
Jun 03, 2009 | Ovens
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
190 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
