Question about LG LS-L1210CL Mini Split Air Conditioner
1 ton ac works for 5min and display E4 - LG LS-L1210CL Mini Split Air Conditioner
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
E4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Posted on Oct 15, 2013
Carrier AC Thermostat displays Error code E4?
E4 indicates an internal memory error. Download the manual and refer to any possible solutions.
May 10, 2015 | Carrier Heating & Cooling
I have a carrier ac moddal 38HKC48DS3002 4 ton that will run for about 10 mintes before off the coppreser and than displing show E4
If unit displays "e4"
1? Check whether the winding resistance and
operation current of the compressor are normal.
2?Check whether the high and low pressure is normal
when the unit is running.
3?Check (whether the coil pipe sensor is normal)
whether the contact of the inserter on the circuit
board is well, the coil pipe temperature sensor is
fixed, the evaporation of the indoor unit is well,
the key is to check the evaporator temperature
detected by the coil pipe temperature sensor has
reached the cooling or heating temperature.
4?Check whether the surface of the condenser is too
dirty, it should be cleaned when it is too dirty.
5?Check whether the capacitance of the outdoor motor
and the fan is damaged, it should be replaced when
it is damaged.
6?If the above items are normal, the electric control
board should be replaced.
Air Condition Fort lauderdale
Apr 12, 2015 | Carrier Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
We have electrolux ac 1.5 ton i n our ac display showing F8 it is not change in remote how remove that.
Jun 17, 2011 | Electrolux Heating & Cooling
We undertake annual maintenance contract for Sanyo VRF air conditioner at standard charter bank nepal ltd., we have found the AC dose not function as well now. The fault shows as E4 on remote control. Now...
E04Indoor seeing error from outdoor. Qty of i/d units connected are less than qtyset. Check; all i/d units are ON,
reset turn off all units wait 5min power up
Helpful?
Jan 28, 2011 | Heating & Cooling
Orient spit ac model os19 mdd display e4 error code
HOU CAN REMOVE E4 ERROR PLEASE TELL ME, ANS
Aug 26, 2010 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
E4 Error in Hunday Split Ac
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
LG LS-L1210CL Mini Split Air Conditioner Logo
566 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
