Question about Vantec NexStar CX NST-200SU-BK 2.5 SATA to USB 2.0/eSATA External Hard Drive Enclosure
Open nexstar cx external hard drive case. I know it opens as my old hard drive is inside and I want to open it and replace it with a new one.
    Scholar:
  • 154 Answers
Posted on Oct 16, 2013
My NexStar CX external drive worked fine until now. When I powered it up this time the power adapter turns a solid blue. Then when I turn the external drive on, the power adapter starts to flash a weak...
I had same symptoms. After wasting two hours, I finally found the HD not making good contact within the enclosure because I have not screwed it in with the frame. It must have broken the connection while I was handling the enclosure. So my suggestion is to check the simple stuff first - connections and loose cables, particularly within the enclosure.
I needed no drivers for my Windows XP Pro.
Jul 19, 2012 | Vantec NexStar 3.5in External Hard Drive...
External hard drive connected to SATA port on old computer. New one doesn't have a SATA port & if I open the case, the warranty will be void. 90% of my photos are on that external drive!
Never mind the warrant as you will not destroy anything.
Open the new PC and fix the drive inside your new machine. There will be free sat connectors on your motherboard, hook your old drive to this and dont forget to power it up as well.
Your pc shold be able to pick up this drive and you can enjoy your old photos again.
Another way is to buy a ESATA card that you can fit on your motherboard slots (you will have to open the case once more). This way you will still be able to use to use your hard drive as an external drive.
If you are still scared of opening up the case you can look for a USB to SATA convertor.
Jul 14, 2011 | Computers & Internet
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Vantec Nexstar 3 driver download
Vantec Nexstar 3 drivers can be found at driverupdate us.Take a look, and enjoy
Apr 04, 2010 | Vantec NexStar-3 External 3.5inch...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
Windows 7 NexStar drivers and installation needed
No device-drivers are needed. Just connect this USB device, and Windows will recognize it. If there is a "one-touch-backup" button, it won't work, but you can still use drag-and-drop to copy files from your internal disk-drive to this external disk-drive.
Jan 01, 2010 | Vantec NexStar-3 External 3.5inch...
I have the external drive case connected and recognized by my notebook. There is a DRecovery file and folder on the drive. I am asked what application to use to open the file. What do I do?
Unless you know what app uses that extension, I'd suggest doing a google search on the extension (ie: .com, .pdf, etc) to see what program it's connected to. You may be able to open it in a text file viewer and see enough info to figure out what it is.
Nov 14, 2009 | Vantec 1 Bay NexStar 3 USB 2.0 External...
I have a Nexstar 3 external 3.5 hard drive and it is shown as the F drive under my computer. Now the F drive doesn't show up and when I turn my nexstar on and off it just sounds like a record skipping...
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Jul 30, 2009 | Vantec NexStar-3 External 3.5inch...
Nexstar IDE to USB, Will Not Show Up
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Apr 06, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec NexStar CX NST-200SU-BK 2.5 SATA to USB 2.0/eSATA External Hard Drive Enclosure Logo
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
