Question about JVC DR-MH30S DVD Recorder
The unit does not read DVD-R discs - JVC DR-MH30S DVD Recorder
Liteon dvd recorder lvw1101 starts reading the dvd then says it preparing the disc then it ejects it
The Optical head unit is faulty. The disc is not being read by the head unit laser and so conveys a wrong message which ejects the cd.
Replace the optical head unit assembly but with the correct procedure.
Sep 11, 2010 | Lite On LVW-5045 DVD Recorder
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
Unit was dropped. getting message 'disc can't be read'
Dropping any electrical unit will almost everytime destroy it. Sad but true...this unit may have many problems. I suggest you replace it altogether! Sorry! Thanks for asking!
Jun 03, 2010 | Panasonic DVD-LS90 Portable DVD Player
Load dvd disc, dvd reads disc then comes up with
I am just wondering whether the unit has got condensation inside.
Just try to do this as a process of elimination.
Take the dvd and place in a warm room.Plug it into the mains (try and eject disc if not leave in) and leave for 2-3 hrs
Give it another try..fingers crossed.
Dec 04, 2009 | Panasonic DMRES15 DVD Recorder
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
LG DVD recorder not playing DVD
When a unit does that it can be a fingerprints on a disc not letting it read the disc and or also that it is not finalized. Can also be a disc format that does not work on unit. Some units only work with either -R or +R and not both. Hope this helps
Dec 23, 2008 | Samsung DVD-R155
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Nov 16, 2008 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Does not read disc including cleaning disc
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Dec 23, 2007 | Panasonic DVD-RP56 DVD Player
JVC DR-MH30S DVD Recorder Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
