Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Clicking sound with the unit off. - Broan-NuTone Allure III QS330SS Kitchen Hood
    New Friend:
This has nothing to do with the wind. Our house was recently built. The duct for the Broan fan system beats fairly constantly whether it's windy or not. It's continuous and regular. Yes, before reading this page, I found the source of the noise. Yes, it's the exterior flap. I've noticed that it seems to be caused by a difference in the interior air pressure. In the winter, windows and doors are closed and the thumping seems to be more constant. If I open the back door in the kitchen, however, the noise stops. Sometimes, on the other hand, it stops by itself. I actually called Broan customer service and I'm a bit unclear, but it sounded as if others may have complained about this. For what it's worth, the representative recommended weather stripping around the vent.
Posted on Feb 08, 2016
  • 38 Answers
Its probaly the duct. There is a little hinged door which is in the ducking right where the fan connects to your duct's, somtimes they play in the wind. I have heard this problem before. Is the clicking perfectly sycronized?
Posted on May 19, 2008
SOURCE:
It ask ing the code 00000000
Go to Control Panel - Device Manager & find your Printer i.e. little arrow by the Imaging devices. Right click the Canon & click upgrade drivers, then clik the upper choice & it will go to Microsoft & find the correct driver for that unit & install it. (must be on line) That should solve your problem If not call Cannon
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 07, 2014 | Whirlpool Inglis IP4400 Washer
Inglis dryer making thumping sound when drying
is the unit level, open the dryer try moving the drum around, see if the drum loose, there mite something in the machine that got caught on the drum some how and when it goes around it bangs,
you mite try spinning the dryer without turning it on and listen to the drum and see if you can hear any thing hitting the drum or what is make those load sounds. if you cannot turn the drum manually you mite bribe a guy or friend to check it out for a beer or glass of wine, and if they down drink bake some cookies.
good luck rod
Dec 04, 2012 | Whirlpool Inglis IP8200 Dryer
Inglis refrigerator no water to ice cube tray
Had the same problem once. I'm assuming all of the water connections have been made properly.
Often the water line delivering the water will freeze just inside the freezer. .Pull the unit away from the wall and follow the line into the unit. Use a hair dryer to defrost the line.
Jun 05, 2012 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My whirlpool inglis ele will not come on????
The Whirlpool Inglis has had a lot of problems with the door switch. Which would keep the unit from starting.
Jan 02, 2012 | Whirlpool Inglis IP8200 Dryer
Fridge not defrosting right water in bottom of freezer then turns to ice.
It sounds like the unit is defrosting, but the drain for the water from the melted ice is plugged. Check that before calling a repairman.
Sep 28, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
05 Nissan Sentra SE-R factory radio will not play/eject cd.
your eject mecanism is n.f.g ( no fu$#ing good) take it to nissan and see if they can service it, if they tell you need a new deck, buy an aftermarket one, (its cheaper)
May 05, 2009 | Car Audio & Video
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
471 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
