Question about Brother LS-1217 Mechanical Sewing Machine
Brother machine vx581s modeldocuments - Brother LS-1217 Mechanical Sewing Machine
Brother CS6000, error message E6
since the motor is locked it could mean the motor went bad or
the machine may have a part that is damaged or borken
it would be a good idea to have the machine checked
here are 4 different free manual I found for the machine, you can
look and see which one is right for the machine and see if you can
find a better solution than what I gave you.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000B_EN_2888.pdf
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000i_EN_2889.pdf
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000T_EN_2890.pdf
Feb 07, 2013 | Brother CS6000i Computerized Sewing...
My brother cs6000 won't sew buttonholes
change the needle
some machines have a button hole lever that must be pulled down
before the button hole is started
but it's also possible that the machine needs to be check to see if
there is something is wrong with a part inside
check the feed dog to make sure it's in the up position
if you don't have a manual here is links that you can choose the right one
Sep 04, 2012 | Brother CS-6000
Brother LS-1217 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
