Question about Clarion Car Audio & Video
Isuzu radio video mcu connect error
My Isuzu truck radio reads "video MCU connection error" how do I correct this problem?
no year truck.
nor model isuzu..
this it?
stock radio? aftermarket?
Oct 28, 2015 | Isuzu Cars & Trucks
Tip
F06 error code. Its not what you think
Had F06 error usually when the washer went into spin cycle. Followed all tips on different sights. No real concrete solutions to my problem. Sense my problem was intermittent I ruled out the motor. I started looking at my MCU and found my heat sink was really hot to the touch. I slipped MCU out of wash machine still electrically connected and put my window fan on MCU while operating and washer worked perfectly. I the went down to Radio Shack and picked up a 115v CPU fan ($20) and installed on my heat sink. Just splice fan wires to MCU power wires (wire connector w/ the 2 largest pink wires). Mount fan creatively to heat sink (tywraps, hot glue gun, however) . I saved $150 and the heartache down the road. I think this a common problem for that MCU. Hope this helped. <br /> Robert, Aircraft Technician
on Oct 24, 2010 | Kenmore HE2 Plus Front Load Washer
Error F2 on Sharp AR5516
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 09, 2014 | Sharp Office Equipment & Supplies
Error F28
The F28 code is a comm failure between the MCU and the CCU. First, check the wiring harnes connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
Yes, I read a couple past members that diagnosed it as the MCU being the cause more than the CCU.
So you can order the MCU and/or the CCU, then I'd install the MCU first to see if that fixes it.
Oct 14, 2012 | Whirlpool WFW8300SW
What is fault FO6
F/06 Washing Machine Error code -Motor tach Error code, control board not sensing motor. If error code appears in the high spin speed mode the door will be unlocked after three minutes.
-Check connections between washing machine motor and MCU (Motor Control Unit)
-Check wire connection on the MCU to the CCU (Central Control Unit) The CCU is on the top of the washer.
CHeck this video, as reference guide...
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 17, 2011 | Washing Machines
Error code f15
Error F15 Motor Control Unit (MCU) Error
If the MCU detects multiple resets or errors during a wash cycle it will go into this error mode.
Potential Causes
- Check wiring harness connections to the MCU, the motor, and Central Control Unit (CCL)
-Check Drive belt
-Check MCU
-Check Motor
-Check Wire Harness
Good luck.
Oct 17, 2011 | Washing Machines
45682 error code f 15
Potential Causes
-Check Drive belt
-Check MCU
-Check Motor
-Check Wire Harness
Good luck.
Oct 17, 2011 | Kenmore Washing Machines
My machine shows an f11 or f14 error code and it won't work. What can I do?
Circuit Board Medics can rebuild and upgrade the CCU to eliminate the F11 error and prevent it from happening again. Find more details at http://circuitboardmedics.com/whirlpool-f11-code/
This video shows how to remove the CCU from the machine.
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F06
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool Washing Machines
F11 code come up when it is ready to drain and spin
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
Service manual video and more HERE
Feb 10, 2011 | Kenmore Washing Machines
Car Audio & Video Logo
128 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
