Question about Garden
Onga jsp120 can you please supply parts diagram
How old is the Onga 443? Do you have a pic of it please?
Hello, Ria -
Only the manufacturer of the Onga 443 MAY be able to tell you how old your pump is. You would have to provide the serial number for the pump, in hopes the company has manufacturing records in its archives. The company archives should probably have photographs of the Onga 443.
I refer you to Pentair, the oompany which owns the Onga brand name and manufactures the pumps. See the Pentair Contact Us page to find the email address for Customer Service:
http://www.onga.com.au/contact-us/
The email addresses there seem to be for sales. I would still use the email address for the country where you reside and ask that your message be forwarded to Customer Service.
Best wishes.
Jan 21, 2018 | Plumbing
The Onga pump turns on and off.
that pump has a pressure switch that turns it on and off
which onga model
whats the actual fault ?
Sep 10, 2016 | Plumbing
My bathmaster v2 onga pump has a flashing red light on control pad that flashers 3 times with 1 sec intervals pump does not work please help
if the controller is flashing it means that there is no water to pump
check water supply to the pump
Jun 01, 2016 | Cars & Trucks
How do I fit a seal to an Onga JSP110, and what way does it go in?
Try to get an operator's manual from the dealer, or Google Onga JSP110 seal replacement.
Aug 11, 2015 | Plumbing
Wont work ongas
Is it automatic ignition? check gas supply, jet clear and thermal safety cutout.
Apr 06, 2014 | Refrigerators
I have an onga model 445 pump wont work on a generator
You can try running a heavier Gage or shorter cord to the genarator. If that's been done try useing a power suppley box commeing from your gen. not a surge protector this will have battries inside it, doing this will cutt down on electrical resistance. If those don't work you will need a bigger gen. The problem is the amprage is to low, one more thing, look in to a inline a/c compasitor
Apr 21, 2010 | Plumbing
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
