Name an password for g202 - Computers & Internet
    Sergeant:
  • 396 Answers
If you reset (hold in the reset button for 20 seconds the router the default will be username: admin and password: admin
This will change all of your customized settings, of course but it is the easiest way to fix this.
Posted on Oct 12, 2013
I cannot located the answer to question, where the grounds connections on 2005 Aveo ls how name are they
G101
Under the ECM
Harness Routing Views
G102
Behind the left headlamp to left of battery
Harness Routing Views --
G103
On starter mounting bolt
G104
Behind the right headlamp under air cleaner
G105
On the engine block, near the starter
G201
Behind the left side of the ashtray
G202
Behind the right side of the ashtray
G301
Behind the passenger kick panel
G401 - Hatchback
On the left side of the rear compartment panel
G401 - Notchback
G402 - Hatchback
On the right side of the rear compartment panel
G402 - Notchback
In the rear compartment, on the rear panel next to the deck lid striker
Oct 18, 2015 | Chevrolet Cars & Trucks
Where is the G202 and G203 fuse for a 2002 PT Cruiser located
G202&G203 are grounds if I knew what you are trying to fix it would be more helpful the power side of G202 uses fuses #5&9 for the airbag system G203 uses fuses #7,10,&20 for several interior components fuse block for #5,7,9,10 left of dash interior and power distribution under hood behind battery for#20
Mar 16, 2015 | 2002 Chrysler PT Cruiser
Don't understand how to set password. please help
Plug the router into the power socket and configure you own machine to obtain IP address automatically. Load up Internet explorer and type in http:/192168.xxx.xxx which is the local address of your router. You should then get a password screen. Enter default user name and password and it will take you to the configuration screen. The full IP address and user name and password are dependant on which model you have. See list below From there you need to read the instructions very carefully and match it with the information provided by your ISP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
? Q: What is the default IP address, username, and password for routers? ? A
ZSR0104
192.168.8.1
Administrator password: admin
ZSR0104M
192.168.1.1
Login password: No Password
ZSR0104B
192.168.1.1
User Name: admin
Password: 0000
ZSR0104AS-01
192.168.8.1
Administrator password: No password
ZSR0104E
192.168.2.1
ZSR0104CP (Grey color)
192.168.1.1
User Name: admin
Password: admin
ZSR0104CP-05 (Blue color)
192.168.10.1
User Name: guest
Password: guest
ZSR0104WE-01
192.168.2.1
ZSR0104WE-04
192.168.2.1
User Name: admin
Password: 1234
ZSR0104WE-05
192.168.1.254
User Name: admin
Password: 1234
ZSR1104WE
192.168.2.1
User Name: Empty
Password: Empty
ZSR0104DE
192.168.2.1
ZSR0104FS
192.168.1.1
User Name: admin
Password: admin
ZSR0104UP
192.168.1.1
User Name: admin
Password: 0000
Dec 22, 2010 | Zonet Computers & Internet
Secutiry issue
You will need to access your router and configure your wireless settings. If you are uncertain about the password/username to access the router 0 then you might find it on label at the backside of the router.
Failing this - the favourite combinations are :
Username admin
Password admin
or sustitute "password" (without the quotes) as the password. If that does not work then you could "google" the question.
Feb 20, 2009 | Zyxel Prestige 600WH Wireless Router...
Trying to fit G202 electronic ignition to G11 Charade. The G202 coil has blue/brown wire and black/blue. G202 distributor has black/brown wire and black. Can you tell me where these wires should go?
The colour coded wires seem to differ at randomn. To identify the cables:
Dizzy:- use a multimeter set on ohms.. When you measure about 3 meg ohms, your red probe is on the +ve wire and the black probe is the signal to the coil.
For the coil, it hard to measure the primary resistance so the general convemtion is looking at the pins on the coil with the taper at the top, the +ve is on the right and the signal (coil -ve) is on the left. Sometimes you'll notice one of the wires on the coil is a thicker gauge, which is generally the +ve.
Jul 30, 2008 | 1990 Daihatsu Charade
Pc crashes
Are you using your ISP's software? I had that problem with BT's home hub thingies, the G202 user interface would load up then either crash or disappear. I uninstalled all BT related stuff and then things went fine.
Do you run any firewall and anit-virus software at start-up?
Feb 08, 2008 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
