Question about Olympus SP-620UZ Digital Camera Black with 16GB Card Batteries Charger
When I try to take a picture with my Olympus SP-620UZ the lens zooms in and out. it will not take a picture
SOURCE: Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Posted on Mar 15, 2009
BillB-SA
  • 2761 Answers
SOURCE: Olympus SP-560UZ "Zoom Error" then shuts down
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
  • 11967 Answers
SOURCE: lens is stuck in full zoom position Olympus 7010 camera
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
  • 11967 Answers
SOURCE: My Olympus SP-550UZ 18x optical zoom has a
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Posted on Jan 04, 2010
I havea an olympus sp-350, shutter is stuck so
I had the same problem, so tried putting the zoom fully on to take a picture.
It worked.
May 12, 2010 | Olympus SP-350 Digital Camera
I dropped my olympus 540 zoom camera and lens cover is jammed
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus SP-350 Digital Camera
Turns on. Lens zooms in and out, gives me "Zoom Error", shuts off
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 23, 2009 | Olympus SP-500 UZ Digital Camera
Erratic zoom operation
lens track may be messed up.. send to repair center
Feb 11, 2009 | Olympus SP-350 Digital Camera
Broken Zoom on Olympus sp-510
Unfortunately this is a repair issue with the camera. You may want to call Olympus Customer Service to discuss their repair policy and procedures. Their telephone number is 800-622-6372 option 2 and then option 3.
Jan 02, 2009 | Olympus SP-510 UZ Digital Camera
Zoom error olympus sp-310
no the memory card is not the problem .... the internal gears or blocks which intialises the lens may have been dislocated due to which this problem is occuring ,..... it has to be fixed from a repairman ,....
Dec 07, 2008 | Olympus Stylus 700 / 700 Digital Camera
I have an Olympus SP 320 camera, zoom error comes up and it shuts off
I just pulled my 320 out after not using it for 4 months and the lens extended and zoom error began flashing on the screen. After reading a few other post on the net about how much it cost I decided the camera was a goner. For good measure I banged it on my mouse pad a couple times and the lens suddenly retracted and it is now working fine. Doubt it will work very often but might be worth a try. Make sure you hit it on something soft to prevent other damage.
Sep 15, 2008 | Olympus SP-320 Digital Camera
Zoom Error
Have you tried changing the batteries to new/charged ones?
Jul 21, 2008 | Olympus SP-310 Digital Camera
Olympus Camera
if you go to the olympusamerica.com/store you will see the telephoto lens but you will need the cla-10 adapter to use it with your camera
although you do get more telephoto with it... you can turn the digital zoom on in the camera and go to 90+ times zoom
Jan 28, 2008 | Olympus SP-550 UZ Digital Camera
Olympus SP-620UZ Digital Camera Black with 16GB Card Batteries Charger Logo
14 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
