Question about Boating
I have a 350 mpi mercruiser that wont start after it has been stopped after a run for about half an hour. the engine splutters and seems to be starving for fuel. only happens stopped and left for half an hour.after engine is cold starts and rune fine. no problems in running and fuel pressure is spec at 43psi. all running temps and gauges are at spec. the problem "developed" intermittantly but now it breaks down regularly. i have checked iac valve and non return valve from fuel tank, all ok.
  • 433 Answers
Agree above, check plugs see if the are wet, could actually be flooded condition due to bad injectors
Posted on May 27, 2017
  • 3,859 Answers
Have you checked the spark plugs ? and its leads, the spark plug can tell you a lot about how the engine is running.
My 1985 4-winns mercruiser 4 cylinder boat runs great for twenty minutes to a half hour then the motor misses and stalls out. After about thirty minutes the boat starts back up and runs great for anot
Check the torque on the head bolts. I can't tell you what it is, been a long time. If they are good, run it till it dies. Then check for spark at the plugs or coil/s. No spark replace the coil/s. My guess would be coils. But I have seen the head loosen up.
Sep 28, 2014 | Seloc Tune Up Repair Manuals Type...
Why is it hard to start my Mercruiser 7.4L MPI after a hot run?
Electric choke? Try retrofitting a manual choke. I think the electric choke is closing over a hot engine, thinking that the engine's cooler than it really is. A manual choke will allow you to start it with no choke at all when you know the motor's already warmed up.
Jul 25, 2014 | Mercury Marine Mercruiser 350 - 454 - 5.7...
HOW TO REMOVE A FLYWHEEL FROM 1985 MERCRUISER 190 ENGINE
Hi, I have a question, is it the mercruiser 190 marine engine that is based on the 350 chev engine
Jan 23, 2014 | Cars & Trucks
F350 super duty, after running for an hour wont restart for a couple hours runs fine once you getted started
sounds like ipr valve
located under turbo 2 wire 1 conectorwire clip on
1 3/8 wrench to removed after turbo and air system been pulled off
get your new valve at your local international dealer
ask for ipr valve for vt365 engine bet you it's half price and same part
make sure that screen at end of valve came out with valve use small pick hook to remove if not
good luck
Feb 28, 2011 | 2006 Ford F 350 Super Duty
Running problem in monsoon season in Daewoo Matiz.
Has the clutch been replaced recently? There is an earth wire under one of the bell housing bolts,if not refitted can cause all sorts of problems.
Jul 19, 2009 | 2000 Daewoo Lanos
2008 Derbi Cross City 125 running problems
if you turn a motorbike tank into reserve..
the patrol wont go to a little filter.. soo.. thats the splutter and so..
Jul 10, 2009 | 2008 Derbi Cross city
Boating Logo
1,141 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
