When I turn on pjd5126(viewsonic projector), regular line appears on the screen.
Marrie
  • 563 Answers
SOURCE: Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Posted on Mar 26, 2008
  • 5 Answers
SOURCE: red lines on the screen
Check out this solution for the same problem:
http://www.fixya.com/support/t305560-even_spaced_vertical_lines_across_whole
Posted on Aug 01, 2009
projdoc
  • 2236 Answers
SOURCE: viewsonic projector pj501 - Has purple bloch with
2 issues- the light filter on one of the lcd panels is burnt due to excessive dust and heat. and one of the lcd panels is shot. time to replace the entire optical engine, unless you can get the prism assembly. otherwise, replace the projector. if you do, remember to keep it clean.
Posted on Nov 17, 2009
Testimonial: "Thanks for the help. Looks like the trash for this one!"
jerry_kramer
  • 3904 Answers
SOURCE: dell 1201mp projector screen flickering black lines with svga cable?
If you projector can not process SVGA then no there is nothing you can do
Posted on Dec 16, 2015
Testimonial: "http://www.projector-manual.com/dell-1201mp.html This shows svga (4.3) does that mean it can process svga??? im confused"
Dell 1201mp projector screen flickering black lines with svga cable?
Dec 16, 2015 | Dell 1201MP Projector
When I turn on pjd5126(viewsonic projector), vertical regular lines appears on the screen.
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Oct 12, 2013 | Office Equipment & Supplies
Computer screen on, Projector off
If you are running Windows 7\8:
Leave the ViewSonic projector on.
Right click anywhere on the desktop and select "Screen Resolution".
In the display column, it will give you an option to select your computer monitor, the ViewSonic, or to clone the displays.
Select your computer monitor display only.
Shut off the ViewSonic projector.
If you are running Windows XP:
The process is basically the same except you find the settings under Control Panel > Display.
Jul 09, 2013 | ViewSonic Office Equipment & Supplies
Blotches screen
the problem may be from power cord. call a service center for checking the power cord.
May 03, 2013 | ViewSonic PJD6381 PROJ XGA DLP 24001...
It worked beautifully last night with my macbook in a test run of my powerpoint, but this morning I plugged it in for the REAL presentation it didnt work. A bright, clear picture of the Viewsonic Logo...
you might need to turn off your computer .
then connect the data projector
and turn on data projector
then turn on computer
hopefully it detects the data projector is connected and switches windows to duplicate projection
On my P.C. F4 key in windows Switches the display manually to duplicate, alternate screen or pc screen only or projector screen only.
As I am not familiar with Apple this support article below might explain the switching of display outputs available on Apple Mac.
https://support.apple.com/en-au/HT202351
Mar 23, 2017 | ViewSonic PJ458D DLP Projector Multimedia...
Viewsonic projector pj501 - Has purple bloch with
Nov 17, 2009 | ViewSonic PJ501 Multimedia Projector
Viewsonic Projector PJ506D not working
proable solution the cooling fan is giving problems. the whistling sound most likely is fan rubbing on a wire??? The unit gets over heated and turns off for protection. Good luck
Aug 19, 2009 | ViewSonic PJ506D DLP Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Hi guys
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
k24674
