When I turn on pjd5126(viewsonic projector), vertical regular lines appears on the screen.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Posted on Mar 25, 2014
3 Suggested Answers
  • 1170 Answers
SOURCE: Vertical line white, regular, blinking.
I don't think it's the bulb. Sounds like an LCD panel issue. Maybe one or more of the 3 LCD panels is either not working right or the unit has been dropped/jarred and the panels have moved (All three have to line up right optically to give the right colours). You need to take the projector to a qualified service centre.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Posted on Apr 01, 2009
  • 269 Answers
SOURCE: x2 projector A somewhat irregular vertical line
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Posted on May 04, 2010
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
Thank You, Arjun.
Apr 01, 2009 | Acer Projector Lamp for PD110, PD110z
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Display
HI,
Disconnect the monitor from the computer and check if the vertical line still appears on the screen . If yes the monitor needs to be replaced.
Generally all viewsonic screens come with 3 yr warranty and you can call them up for repairs or replacements .
Thanks
Proton
Jul 26, 2008 | ViewSonic VX2235wm LCD Monitor
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
142 people viewed this question
k24674
jasbo
jasbo
