Question about Toymax Latte Communications M1 MP3 Player
When i plug in my latte m1 mp3 player to my computer (windows), it comes out to bu an unknown device and i can't put any music in my mp3 player. help!!
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
I have a square lookin delstar mp3 and i don't know how to put songs in it.......culd u tell me how....pleze???? i want to get the music from youtube..oh yeah..it has 4GB!!! I LOST THE CD DRIVER SO I CAN...
if you have a windows machine, first plug the mp3 player in to one of the empty usb ports on your computer and let windows install it, now use windows media player to songs to it using sync or copy music to device
Jun 23, 2009 | Delstar DS 31024 MP3 Player
I lost my book user manual for my mp3 player
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Mar 05, 2009 | Bell Technology Latte Communications M1 ...
I can't see haif the display!
Latte makes several mp3 players. If you have the Latte Neon, you will need to go into the settings menu and adjust the backlight settings:
Brightness control: +1, +2, +3, +4, +5, the higher level, the brighter
Backlight display mode: Normal and Energy-saving modes. Set as no operation and only darker display in normal "Backlight Time", and it will close the display if you set as Energy-saving mode.
If you have the Latte Ice, go into Settings --> Display and adjust the same settings as above.
-Tha Mp3 Doctor
Jan 23, 2009 | Bell Technology Latte Communications M1 ...
Downloading music trouble
After you've downloaded the music files you want from Lime wire put them in your music folder on your computer ,then you need to sync your MP3 player through windows media player. plug in your mp3 player then open windows media player, on the top right there is tab says sync. click on refresh devices and your mp3 player should show up on the right window pane in windows media player. From there you can drag all your music onto it and press sync!
Hope this works
Dan
Feb 22, 2008 | iLO MP3 Player
Problem with my sansa e200
The issue you have described with your portable device in most cases can be resolved by formatting your device. Please follow these steps even if you have already attempted them once before.
Please note that this will remove all music from your device.
Formatting the device in Windows Media Player
1. Open Windows Media Player with your MP3 player connected to the computer
2. At the top of windows Media Player select the Sync tab at the top
3. The MP3 player should be recognized on the right hand side and say "Your Player Name"
4. Above the player name is a button that says "Format Storage Media" click this button to erase all the data from the player
5. Continue with the acknowledgement of erasing all data on disk.
Jan 17, 2008 | SanDisk Sansa e200 MP3 Player
Folder
I might be wrong but it sounds like your os is having a problem connecting to the player? assuming windows go to device manager by right clicking on my computer goto manage then when the management console comes up go to device manager find your device, it might be 'unknown device' or under portable devices. delete/uninstall it then unplug it for a second and then plug it back in, it should get redected and work. good luck
Aug 13, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Toymax Latte Communications M1  MP3 Player Logo
16 people viewed this question
Top Toymax Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Toymax Audio Player and Recorder Expert? Answer questions, earn points and help others
