Question about Acer Aspire 5520-5908 Notebook
When i press the power button,the light blinks but fan doesn't rotate and in some seconds the light goes out........how can i fix it?
    Sergeant:
  • 252 Answers
You cant do anything. Need to replace/repair the motherboard. its mb issue.
Posted on Oct 12, 2013
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 01, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
Just replaced the battery remote will NOT work.... I have a very high ceiling.... this is getting annoying.... when I press the remote I get a red light wether I ask for fan or light.... light just blinks...
Some remotes have a learn button in them, when it lose its power you need to relearn it. Hold the small button for about 5 seconds, to reprogram it with the receiver. If it doesn't work ,then your receiver may need to be replaced.
Sep 03, 2011 | Hunter Ceiling Fan Remote Transmitter...
When we turn on the console the light goes green for a few seconds then to a blinking red, what do we do? Is there a reset?
There is a reset but I don't think it will solve your problem. A blinking red light usually means there is a hardware malfunction somewhere. Your best bet would be to call Sony at 1800mysony and get it fixed by them. You could try a reset..you can do this by holding the power button down until it restarts itself and then letting go and holding the button down once more. If this doesn't work you are definitely looking at hardware problems. You could try getting some canned air and blowing out all of the vents, it could be that your vents are plugged or your fan is clogged up but if it doesn't start up and run at all it's probably a more severe issue.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
It will not power on when I press the power button and there is a blinking "A" light going off. When I press the power button the "A" light with a lock around it blinks, the fan sounds like it is going to...
try to run diags, press and hold fn key then press the power button an release them both at the same time when the computer turns on, check for any error message, or try to reseat your memory modules too
Oct 04, 2009 | Dell Latitude E6500 Laptop
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Acer Aspire 5520-5908 Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
