I have a canon IP6700 printer, rated 110 ACvolts, accidentally plugged into 220 AC outlet. Is it broke the whole unit or just the power supply section of the printer?
    Sergeant:
  • 252 Answers
Need to replace the power supply. And also some other parts can be damaged.
Posted on Oct 12, 2013
3 Suggested Answers
steve6375
  • 395 Answers
SOURCE: Eee PC 2G power supply
Why don't you contact the supplier and get a replacement. It must still be within its 1 year warranty period?
Posted on Aug 15, 2008
Geekman
  • 32281 Answers
SOURCE: my a.c. power supply plug at the computer broke.
Yes you can, just make sure that the switch mode power supply you purchase has the same wattage or greater wattage that your old switch mode power supply.
Posted on May 16, 2010
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
110 volts, rated TV was plugged into 220 volts power supply. Now when it was plugged into an 110 volts supply its not getting on? What could be the causes? and please suggest solutions.
It probably fried the power supply in the TV unfortunately. If the electrical surge stopped there then it should just be a matter of swapping out the power supply. Provide a make and model of television and I will see if I can help find one with instructions on how to change it.
Nov 24, 2012 | Office Equipment & Supplies
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Mar 25, 2012 | HP LaserJet 1300 Printer
What is the polarity and voltage setting for the hot water on demand system
Well if you buy a 220 system it will be 220 volts.
All the bigger systems like for whole house will be 220.
some smaller under sink models will be 110.
There is no polarity since it is AC. If you find something that says polarity on a on demand water heater then somebody at the factory is smoking something.
110 has 3 wires. all tests need done with a multimeter on the AC setting.
Black wire will be 110 volts AC, White wire is neutral and green wire is ground.
220 system also has 3 wires. Colors can vary a bit here but usually it goes like this.
Red wire is 110 AC - Black wire is 110 AC and white wire is Neutral or ground.
Test to ground they read 110 Volts AC test to each other they read 220 AC because they are out of Phase to each other.
PLEASE note. Always get a certified electrician to work on these units. If you feel you are just as good as any electrician, please make sure you have a family member nearby with a phone that can dial 911. 110AC can kill you and 220 AC can kill you faster and deader.
To know whether any particular unit is 110 or 220 we would have to have the model number to look it up. Some can be either and in this case the only way to know is to take the junction box apart. If it is just plugging into a regular wall outlet then it is 110. If it looks like a special plug or like a dryer plug then it is 220.
Hope that helps. Have a great weekend.
Apr 16, 2010 | Coleman Hot Water On Demand
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Error e803 checked power supply next to ac cord
Well most likely its a low voltage problem, check power outlet (110/220) or you need to replace the low voltage power supply board. Before replacing the power supply board you must check that the voltage is 24V by using a volt meter.
Jan 22, 2010 | Canon Office Equipment & Supplies
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
