Question about HP DeskJet 950c / ScanJet 5370C InkJet Printer
Hp deskjet 950c drivers for windows 7 64bit - HP DeskJet 950c / ScanJet 5370C InkJet Printer
  • 5 Answers
SOURCE: DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Posted on Feb 11, 2008
  • 24 Answers
SOURCE: HP Deskjet 3820
If you want to keep that 3820 going, you need to learn how to maintenance the gears under the service station every 6 months or so.
This is FYI and I wish I had known how to prevent this before it happened to me 3 times since 2002. Now I can prevent it, almmost no one can fix it.
Ink buildup in the internal service station causes the small poorly designed pusher cogs on two drive gears to snap off and the printer is instantly converted to junk.
HP was giving new printers out for this problem till Jan 06 or so as they realized it was a poor design.
I fixed one with parts from an electronically damaged unit, but usually the blinking lights and "won't print no matter what" problem are sheared gears. Parts are not available. Some people made metal gears (the only answer) on a very short run basis in Europe several years ago because people LOVE this printer.
Once you know the problem, it's simple to keep it from happening with some maintenance, but once they shear, it's over.
There was some kind of paper-clip fix that was solving the problem even with sheared gears, but I was never able to understand exactly how it was done. Needed a pic or two.
Otherwise a great printer, huge cartridges last a long time, great quality on photos too.
I have to keep mine running to have a happy wife.
Posted on Apr 05, 2008
benwabnick
  • 2404 Answers
SOURCE: Unable to install driver of HP deskjet 3740 on window 7
HP doesn't have the drivers available for windows 7 cause its only in Beta and they won't have it until windows 7 becomes official and available in stores. The only chance would be if you go into the control panel and then add printers. See if in there it has your make and model of your printer. If it doesn't then try a printer that is similar and it might install it. If you still can't get it to install then you'll have to wait for HP to come out with a driver for windows 7.
Posted on Jun 08, 2009
BlacMamba
  • 215 Answers
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
Posted on Jan 02, 2010
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32 bit version of Windows 7 you can add a driver using the following: go to the Devices and Printers folder, Add a printer, Local printer, LPT1: (or which ever parallel port the printer is connected to), select the Deskjet 720c driver. You may need to click on the Windows Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
Posted on Jan 05, 2010
Printing Margins settings incorrect with Windows 7
if the printer have disk use it and install printer driver
Dec 21, 2013 | HP DeskJet 950c InkJet Printer
My deskjet 950C printer will not print out anything exept the test sheet. everything just goes in a queue. what should i do? Please get back to me as soon as possible, Thank you.
If it will only print the test sheet the printer is not seeing the computer. Check your cable connections and your drivers. Try another USB port on the computer. Go to 'Printers and Faxes' and see if your printer is listed there, if not, install it using the software supplied or look for it in the Windows list. You can also try access the Printer Assistant which comes with HP products and should be there it the software is correctly installed. There is help and support in that as well.
Apr 24, 2011 | HP DeskJet 950c InkJet Printer
I need a manual Hp Deskjet 950C
Here you go: http://support.dell.com/support/edocs/acc/hp950c/using.htm
Mar 09, 2011 | Office Equipment & Supplies
HP Deskjet 950c won't print black
You might be able to use a q-tip with alcohol or acetone to loosen and clean residual ink from the inside and bottom of the black printer cartridge tray--I've even had to use compressed air after loosening the junk after my HP sat for a year. Btw, I'm sure you know this, but the contact pads need to be clean and free of factory tape. I hope this helps.
Feb 22, 2010 | HP DeskJet 950c InkJet Printer
Can I get a driver to use your hp ScanJet 5370c
Yes, there is... but the catch is you have to order it from HP.
I thought it would be a free download as they providde for Windows OS, but that's not the case.
Here's a link to order it for MacOSX...
https://warp2.external.hp.com/Driver/dr_country_select.asp?Product=C8477-14328&lang=en&cc=us
Nov 08, 2009 | HP DeskJet 950c / ScanJet 5370C InkJet...
HP Deskjet 950C. Printing is coming out with one
1.driver problem
2.their may not be enough toner
3.virus in system
try to solve above may give the solution
Aug 31, 2009 | Office Equipment & Supplies
I have a HP VPavillion computer with Vista and an
Vista is tricky like that. do you have the cd that came with printer try to reinstall it. maybe go to HP site update the drivers.
Jun 10, 2009 | HP DeskJet 950c InkJet Printer
HP DeskJet 950c / ScanJet 5370C InkJet Printer Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
