Question about Kitchen Appliances - Others
Can not disassemble tefal softline memo - Kitchen Appliances - Others
I need Instruction Manuel for A Diplomat ADP3120 Softline 600EM Lamona fitted oven
Google it or ask the manufacturer if they have one available
Sep 09, 2016 | Ovens
Hi. Please can you help I need a instruction manual for my Tefal slow cooker steamer rice cooker porridge maker model no. RK701115
http://www.tefal.com/All+Products/Cooking+Appliances/Multi+cookers/Products/Tefal+4+in+1+Rice+Cooker/Tefal+4+in+1+Rice+Cooker.htm
If you go to that site you can download the manual you need. Regards, Kat
Aug 19, 2011 | Microwave Ovens
I lost the manual for the Tefal DO250D34 food processor. can anyone help me find on online?
Tefal reports this as their food processor, although they don't list D0250D34 anywhere. Here is a link to the only user manual Tefal has across all of their sites around the world...
http://www.tefal.com/NR/rdonlyres/6D99133B-88A6-4BF1-8A71-780B49A7AC74/150/KALEO_eng.PDF
Jan 28, 2010 | Tefal Food Processors
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Nov 01, 2009 | Tefal Irons
Fisher and Paykel Softline Refrigerator Globe Replacement
Remove the temp control housing so you can get at the bulb more easily. It unscrews counter-clockwise, it may just be stuck from prolonged seating. If necessary, unplug the fridge, break the bulb, and unscrew the socket with a pair of needle nose pliers on the outer edge of the socket. It may crush the socket, but that's ok, it should come out then. Good luck!
Sep 22, 2009 | Refrigerators
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
How to dismantle a Tefal Aquaspeed 150
no, its not the Aquaspeed 170, but Aquaspeed 150. i succeded to unwrap the housing, but did fail in disconnecting or dismounting the power cord terminal.i could not disassemble the Iron to reach the heater. to dismantle, step 1 unscrew 3 visible screws. step 2 lift the heel cover away, by unsnapping 1 hooks at the right and one at the left side of the heel cover. i used thumnbnail to deform the heel cover for not to wear out the snap-in hooks. step 3 remove the dischalk stick (don't know the right wording in english) step 4 lift the top cover (which covers the spray jet part), 2 hooks at both left and right, use thumbnail or flat screwdriver, start at the top hook. step 5 take off the spray and steam buttons, 1 hook at the front side, 1 hook at the outer back side step 6 take off 2 screws: one keeps the upper half of the handle, the other fixes the water container at the heater plate. Attention: when unmounting the container, and turning the iron upside down, a small (4mm diam, ~10 mm length) silicone cylinder part will fall out, some kind of actor of a bimetal thermo switch in the ground plate, which probably controls water flow (not the electric thermostate) so far so good, i got my problem solved, but would like to know how to disassemble the container from the ground plate and how to replace the cable?
Apr 12, 2007 | Tefal Aquaspeed 170 Iron
Kitchen Appliances - Others Logo
64 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
