Question about Ricoh Caplio GX100 Digital Camera with 24-72mm
Ricoh Caplio GX100. I have to set date\time every time the camera is turned on as if for the first time. Previously it worked normally.
    New Friend:
Panasonic PV-GS39 Mini DV Digital Camcorder
Posted on Oct 12, 2013
jackboy
  • 2985 Answers
SOURCE: ricoh caplio gx 5.1 mega pixels
Email this problem to Ricoh Techincal Support Team This appears to be an internal defect.
Posted on May 26, 2007
SOURCE: ricoh caplio digital camera
Stewin
Problem of lens not retracting fixed in one day by general camera serviceman. He said a part was broken and has fixed it without access to genuine parts.
Posted on Apr 29, 2008
SOURCE: Ricoh Caplio R4 Lens
I have the same problem and it seems that the Caplio R4 is prone to internal lens holder damage when dropped.
Looking around I found repairers that would charge £90 just for looking at the camera.
So I took it apart to see what the damage was. There are two lens (normal and macro) which swing down into position as the camera is started up and as the lens unit extends at the front of the camera.
The arm of the main lens in my camera has broken and the lens then dropped into the area in front of the receptor/pixel thing thus meaning that when the camera is turned off the external extending lens will no longer retract into the body. I might have a go at gluing the part back together but it looks doubtful
Posted on Oct 10, 2008
  • 102366 Answers
SOURCE: caplio R7 error 30-01-23
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
  • 11967 Answers
SOURCE: Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Posted on Feb 25, 2010
How fix lens
What do you mean with how fix lens?
It would be easier if you could tell us what (you think) is wrong with the lens.
Because if the front lens is out, or has a big scratch it would ne difficult for you to do anything.
But it also could be your lens barrel does not come out. If that is wrong, it could be you only have to remove the battery for a few moments and replace the battery, switch on the camera, to see if that helped,
If you still have a problem, can you please tell us what is wrong?
Real defects with new cameras, are best repaired in a certified service centre . In your case, a Ricoh certified service centre.
Jun 16, 2014 | Ricoh Caplio GX100 Digital Camera with...
I want a user manual
The manual for the Ricoh Caplio G3 Digital Camera may be downloaded here:
http://www.ricoh.com/r_dc/caplio/g3/support/manual.html
Apr 21, 2012 | Ricoh Caplio G3 Digital Camera
Card is write-protected. When I try to take a 'photo this message appears on the LCD
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 16, 2010 | Ricoh Caplio GX100 Digital Camera with...
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
Can't download pictures from camera to computer
likely the easiest thing to try is to uninstall the caplio program.
go to start/setting/controlpanel/add remove programs
uninstall caplio program and then reboot.
plug in the camera and try navigating to it through my computer
if it works then reinstall the caplio program.
Jan 27, 2008 | Ricoh Caplio R3 Digital Camera
Ricoh caplio r3 digital camera.
This has happened to me a couple of times. It appeared when the camera was getting a lot of use and it wouldn't turn off - it was jammed on. I had to leave it a few minutes and not touch it - turn it off, then it was ok. I think it was overheated!
Jan 01, 2008 | Ricoh Caplio R3 Digital Camera
Ricoh caplio R5 digital camera
Flash not working Reset the ISO setting to a higher number Invest in a good image editor or even download the free Picasa
Aug 02, 2007 | Ricoh Caplio R5 Digital Camera
This is an easy fix for a camera shop. Just tell them that your lens is off track, and needs to be aligned. It should cost less than $50.00. If you are really good with electronics, you can attempt it yourself. Just let me know if you need the schematic to the camera. Best regards, Bill
May 20, 2006 | Ricoh Caplio R4 Digital Camera
Ricoh Caplio GX100 Digital Camera with 24-72mm Logo
Top Ricoh Cameras Experts
teddyboy
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
