Question about Mitsubishi XD500U-ST DLP Projector
Lots of white and black pixels on display - Mitsubishi XD500U-ST DLP Projector
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
Aug 12, 2014 | Apple iPhone4 4G iPhone 4
Grey spots black screen
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
Sep 29, 2013 | Samsung PS-42A450 42" MULTSYSTEM PLASMA TV...
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Oct 25, 2012 | NEC NP200 Projector
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Contrast ratio of tft monitors
Contrast ratio is the ratio between black and white. So low contrast ratio (5000:1) means you can;t see the screen so well in a bright room (where there's a lot of sunlight) A higher contrast ratio (20000:1) means the screen is brighter so easier to see in bright rooms.
Pixel pitch refers to the distance between pixels. The lower the pixel pitch, the sharper the image
Feb 04, 2008 | Audio Players & Recorders
Mitsubishi XD500U-ST DLP Projector Logo
47 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
