Question about EA Games Battlefield Vietnam WWII mod
This printer uses ink with the following black ink cartridge number and color ink cartridge number. Remember to double-check your black ink cartridge number and color ink cartridge number when purchasing them. For your convenience, when purchasing new ink cartridges, print this page or write down the ink cartridge number on a piece of paper and bring it with you to the store. Using the genuine Canon inks is recommended.
How do i check my ink levels?
Go To Below official EpsonPrinter Page For Your problem. How do monitor the ink levels on my Epson Stylus printer using Windows...
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Apr 18, 2014 | Epson Workforce 520 Printer
I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Canon MP610 Printer
You cannot switch to the larger black cartridge. You are using a CMYK (Cyan, Yellow, Magenta, Black) format for printing color images.
The larger cartridge is used for text only. The smaller black cartridge is used for color or graphic images.
If the black cartridge was not present, every time you needed black in an image, it would have to come from the composition of Cyan, Magenta and Yellow. This would greatly reduce the life of the color cartridges.
Don
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Can't load printer ink cartridges...
Are you using the right cartridges? They should be:
  • PG-40 BLACK (Black Ink Tank)
  • CL-41 Color (Color Ink Tank)
Also check this CANON FAQ:
How do I install the ink cartridge(s)?
Sep 07, 2009 | Canon PIXMA MP190 All-In-One InkJet...
HP Officejet 7110 won't print black and white w/o color cartridge. I never print in color; yet the machine will not print in just black and white without having a color cartridge with ink in it. Why would...
I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye.
To print using only black ink, try doing as follows:
When you click on 'Print' from your browser, the printer properties (or preferences) page opens.
You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows:
1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'.
2. Click on that box to get the advanced settings page to open.
3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'.
4. Click on that and then 'save' or 'apply' those settings.
Then your printer should be using black ink only.
You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink.
Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print.
I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
Apr 28, 2017 | HP OfficeJet 7110 All-In-One Thermal...
Message wrong cartridge on lexmark 7170 printer
for Lexmark x7170 ink cartridge is #32 and #33.
double check the number on the ink cartridge. and make sure to take the tape off the bottom of th eink cartridge before insert it in the cradle.
as far as the cleaning. there are contact pins in the ink cradle and on the bottom of the ink cartridge.
clean them using a coffee filter with little alcohol.
Dec 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printing in black & white when color cartridge ran out
I had the same problem. Had no choice but to buy the colors I ran out to make the printer work. In order to avoid future problems and save on color inked I attempted to follow the steps of a previous posting, however, that did not work for me. This is what I had did. Print, select properties, advance, continue, check box - Black ink only. Remember when you decide to print in color you must reset your setting and take out the check from the - Black ink only.
Sep 08, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Video Game Consoles & Games Logo
53 people viewed this question
Top EA Games Video Game Consoles & Games Experts
James Wishart
Are you an EA Games Video Game Console and Game Expert? Answer questions, earn points and help others
