Question about AEG Ovens
We have just purchased a BP5013001M AEG oven and cannot work out how to wire it. My dad is an electrician but has never wired these ovens in before. Anyone know how?
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
captaynkyrk
  • 170 Answers
SOURCE: Thermostat for kenmore oven wiring
Here's a link for you: http://www.partselect.com. You can put in your make and model and get diagrams of your appliance and see how things connect. Good luck!
Posted on Jul 20, 2008
SOURCE: Wiring Diagram for AEG Build-in Electric Oven B2.6L
can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
SOURCE: replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Posted on Jul 08, 2009
I want to put back my wires to grill element how on AEG E4100 1 OVEN
Unfortunately, this isn't a wiring diagram but can also serve.
See the pictures below:
Dado
Apr 24, 2015 | AEG Ovens
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
My AEG oven needs a PC board, but I cannot find where I can buy one. Can anyone help pleases?
PCB for D5701-4-M is obsolete. I certainly could not find one. Alternative is repair. I used QER Ltd via ebay. Involves removing and identifying part number of board and ordering repair via ebay listing. The trick is to find the correct listing for your board number as it will not be listed under AEG D5701-4-M. For instance, my D5701-4-M, part no. 944171390 (found on plate in bottom right hand corner of main oven) uses board NPPUGN104. It was listed in ebay under Repair pcb / module Zanussi Z0B1060X. Took two attempts to fix, but so far so good.
Nov 19, 2012 | AEG D5701-4 Electric Double Oven
Oven Light Assembly wires
does not matter.
Jan 22, 2012 | AEG Ovens
Aeg double oven 3210 bu model bottom oven not heating up .
your oven element has failed. it can be changed from inside the oven by removeing the back panel and unscrewing the element, take care not to lose the wires when you disconnect them. other wise you have to take the oven out to reconnect the wires
Nov 09, 2010 | Ovens
My AEG B3191-4 oven works for about 30 mins, then seems to cut out... it won't work at all until it has cooled down, and then the cycle starts again... can you tell me which part is likely to need...
Your cooling fan may not be working. either the fan is faulty or its controling device is not switching it on it also allows the fan to run on after the oven has been turned off. its located in the wiring loom behind the switches. part 899661926761-1 costs £26
Jun 08, 2010 | AEG B3101-4 Electric Single Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
AEG U7101-4 Top Oven tripping the fuse after a few minutes
It is more than likely the oven element, as it gets
hotter the insulation in the element is breaking down and causing the trip to operate..
Remove the panel at the rear of the oven and you will see the element there, undo the screws and pull the element towards you, carefully, detach the 2 wires and remove the element.
Be careful not to lose the 2 wires behind the oven rear.
Replace with new element.
Cannot give you a part number, you will have to go to aeg web site.
Dec 12, 2008 | AEG U7101-4 Electric Double Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Nov 04, 2007 | Ovens
Ovens Logo
88 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
