Question about Krups Super Automatic XP 9000 Espresso Machine
XP9000 Krups reset - Krups Super Automatic XP 9000 Espresso Machine
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Krups XP9000 fault message that
Try unplugging machine from power to reset it
Posted on Aug 14, 2008
SOURCE: Krups XP9000 won't recognise water tank is full
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Posted on Mar 08, 2009
SOURCE: krups xp9000 will not brew, but grinds beans.
I also have the same problem with my xp9000. The beans are grinding but no coffee is expressed.... Any advice????
Posted on May 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Re. my last message -
what is the issue please?
Thanks!
Posted on Nov 24, 2010
Krups XP9000 The main fuse blows when using frothling nozzle. Sometimes even just when turning on the machine.
blowing a main fuse is an indication of a short or insulation failure
have an accredited electrician test the unit to find the fault
Apr 17, 2017 | Krups Coffee Makers & Espresso Machines
It always shows fill up beans but the beans container is full.. how to fix this problem for a Krups Xp9000
somewhere I read that there is a window /sensor that needs cleaned really good so it sees the beans
Jul 19, 2015 | Krups Coffee Makers & Espresso Machines
How to remove safely plastic casing on Krups XP9000
Remove book holder at back by pulling it off by hand. Undo the screws visible at the back cover, there's about 4 or 5 or so there. Unclip that centre back panel now screws are out. Remove clear beans cover, remove water tank, lift up the lid to drop grounds direct to brew chamber. Both side lids in open position. Now firmly grip the top cover and try and slide it directly backwards. If it is stuck a firm thump against the front side of the cavity you removed the water tank from while still pulling the top cover backwards will free it up. The sides lift directly upwards to get them off. When replacing the water tank side panel you need the front door open to clear a little spring leg.
Oct 19, 2014 | Krups Coffee Makers & Espresso Machines
Krupps XP9000 won't accept date so therefore won't switch on
Are you attempting to put the date in in the wrong format. USA = month and then day, normal folks day and then month. Check language setting.
Mar 28, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp9000 will not brew, but grinds beans.
May 14, 2010 | Krups Super Automatic XP 9000 Espresso...
Not sure how to take it off cleaning mode. The cleaning button continues to flash?
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={EBDB947E-33FB-42E0-B662-0E13E8D1D4FB}&SelectedProdRef=XP9000
here is a link to the manual. u will need adobe to open it
Jan 20, 2009 | Krups Super Automatic XP 9000 Espresso...
My krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Jan 26, 2008 | DeLonghi EC140 Espresso Machine
Krups Super Automatic XP 9000 Espresso Machine Logo
131 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
