Question about Eclipse EA3422 Car Audio Amplifier
What is the wattage output on this amplifier - Eclipse EA3422 Car Audio Amplifier
    Problem Solver:
  • 19 Answers
Specifications
13.8V Power Supply
Max Power Output 123W x 4 ch (2 ohms)
Power Output (RMS Continuous Power) 2 ohms 70W x 4 ch
4 ohms 50W x 4 ch
4 ohms bridged 140W x 2 ch
THD (Rated Power) @ 2 ohm stereo 0.008%
@ 4 ohm stereo 0.004%
@ 4 ohm bridged 0.008%
Signal to Noise (A-weighted 4 ohm) 105dB
Freq. Response @ 4ohm stereo 20Hz-20kHz +0,-0.7
Crosstalk 4ohm -70dB
Slew Rate 10V/us
Damping Factor @ 60Hz > 200
Input Sensitivity (preout) 0.2-5V
Input Sensitivity (Amp-out) 0.4-10V
Max Current Consumption (4ohm) 50A
Channelflex Crossover
High-Pass Freq Range - 12dB/octive 50~200Hz
Low-Pass Freq Range - 12dB/octive 90Hz (fixed)
Bass Boost (@45Hz) 0~9dB
Subsonic Freq. Range - 12dB/octive 20Hz
All these specs are dependent on the kind of speaks and their ohms rating.
Posted on Dec 03, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
If it doesn't say call the mafactor
Posted on Oct 16, 2013
Output wattage of sony speaker system model ss-cfx250
Passive speakers don't have an output wattage rating, that would be applied to the amplifier :-) The INPUT wattage rating of these speakers is 5 watts RMS per speaker.
Jul 14, 2014 | Sony Audio Players & Recorders
Can u tell me what amp I need to run my 2 x 400w EV sb122 bass speakers and 2 x 300w EV sx300w top speakers
The wattage listed on the speakers is the peak wattage the speakers are rated to handle. You need amplifiers that do not exceed that maximum. A 50 watt amp would drive them fairly well but you would do better with a 100 to 200 watt amplifier. Note: the speaker rating is peak power handling. Amplifiers these days are usually rated at peak output too but sometimes (old or very high quality) amplifiers are rated at sustained power (RMS). If you are working with one of these amplifiers you will need an amplifier with a lower rating. Also make sure the amplifier is designed to run the same load as the speakers. This is usually either 8 ohm or 4 ohm. Make sure the speakers and amplifier are rated the same.
Apr 17, 2013 | Audio Players & Recorders
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
The amplifier keeps burning the tweeters in the speakers after replacement
Please check the wattage of the replaced speakers, now check the cross over in the speakers, if the capacitors are short the voltage might flow into the tweeter coils to burnt them out. Also you can try and reduce the high frequency and also see if the tweeters heat up . If so use high wattage super cooled tweeters.
Check finally for fault in the amplifier output- high voltage/current.
May 12, 2011 | Peavey Pv 2600 Power Amplifier
How do I increase the output wattage of my bodypack?
There's not much what you can do on the transmitterside.
If you will increase the distance you have to work on the receiver.
Use some external directional antenna's and amplifier's.
Regards,
Gerard
May 07, 2010 | Lectrosonics MM400 UHF Body-Pack...
No output on channel B OF PEAVY2000AND1200
You missed something. Use the good channel (A) to compare resistance and or voltage readings against the defective channel. Obviously you've removed the dead short issues (AC fuse is holding) BUT your signal path is still askew. Any transistors/diodes under suspect should be removed from the circuit for proper testing....Glen
Apr 14, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
About converting from 110 volt to 220 volt Sonance Cinema 5150
Yes no problem all you need is a transfromer that converts 230volts AC to 110 volts AC.
Have a look in your yellow pages to find a Transfromer company
located in your vincinity.
You will need to visit him with the wattage of your amplifier and order a step down transfromer. (The wattage is found on the small plate on the rear of the amplifier. Sometimes its written as KVA?.
Please ensure that the plug on the amplifier is changed to specially fit the 110v output of the transformer this is a must as people plug the wrong plug into the wrong socket and burn out the amplifiers.
Cheers YUBEUT.
Apr 19, 2008 | Sonance Cinema 5150 5-Channel Amplifier
Eclipse EA3422 Car Audio Amplifier Logo
96 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
