Question about Gigabyte Computers & Internet
Gateway memory Hi! I have Gigabyte GA-8I915ME Motherboard I was having problem with one of the memory slot so i entered BIOS and changed the memory frequency. Now my PC won't boot, I have cleared the bios but do no avail. Please help!
  • 19 Answers
HOLD del key even before you start your computer, then you start your computer.
If that doesn't help, open your computer and clear CMOS on motherboard, find jumper called clear cmos, but first un-plug Power or turn it off (put switch to 0), then put jumper in clear CMOS for couple of seconds, then try turning it on, ..
If one slot doesn't work, I suggest you try free program: memtest86 ! IT will show you if you have slot or memory problem.
If none from above helps, put one memory out, then try, then put another in, and other out and try.
Hope it helps.
Posted on Oct 14, 2013
PCTServices
  • 120 Answers
SOURCE: Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Posted on Oct 02, 2007
Reddin
SOURCE: ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Posted on Mar 31, 2008
SOURCE: BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
Posted on Sep 22, 2008
Dshack
  • 40 Answers
SOURCE: won't boot
Under normal circumstances you do not need to boot into a drive to flash your BIOS. Normally you would take a dos boot floppy and the latest BIOS firmware and put them on a floppy, which is then inserted into the floppy drive before turning the computer on, and if the bios boot priority is set to boot from floppy before the harddrive, it will ask to boot from the floppy, which allows you to flash the bios from a command line or text graphical interface.
*Note that you may be able to use a cd, but floppy is the oldschool way - if you could boot into an operating system you could use the modern methods which flash the bios while running an OS.
Your board comes with Q-Flash in the BIOS, which means you are able to log into the bios and flash it using this utility and by putting the BIOS firmware on a floppy and inserting it into the computer.
Please see Here for instructions and Here for the latest firmware.
If you cannot access the BIOS, meaning the BIOS is completely bricked, then you will need to buy a new motherboard. Unfortunately there is no way to fix a BIOS which is completely bricked.
Posted on Dec 16, 2008
cpenzes
  • 1102 Answers
SOURCE: Compatable gigabyte ga 81915pm motherboard
you may not have to format
you should be okay
are you sure power supply is not going
remove cd drive and boot see if you can get to safemode
Are you sure you have'nt had pc opened and maybe loosened a memory
I still don't think it's the motherboard.I would go more for a memory or power supply problem
let me know
Posted on Feb 13, 2009
Pci to micro channel bridge
Hello download the drivers here:
http://ee.gigabyte.com/products/page/mb/ga-8i915me-g/download/
Click on the link, to the right, for download.
Good luck
Aug 31, 2012 | Gigabyte GA-8I915ME-G Motherboard
Gigabyte GA-8I915ME-G Motherboard + 1 TB WD HDD
Insert the SATA and Power connector, enter the BIOS and ensure that SATA 2.0 controller is enabled.
Now boot into Windows and click control panel.
Double click Administrative tools and double click Computer Management.
Left on screen: Select Disk Management under the heading, storage.
Here is where the hard drive should be detected. If not present click action, followed by refresh.
Now select your new drive and format it using NTFS.
Take care!
damnor01
Jun 07, 2012 | Gigabyte GA-8I915ME-G Motherboard
Is gigabyte-81915me-c motherboard support 1 gb ddr2 RAM? The Ram is 1 GB DDR2 800Mhz.
This is the RAM specs for this motherboard.
Memory
  1. Type: Dual Channel DDR 400/333
  2. Max capacity: 2 GB
  3. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
Jun 21, 2011 | Gigabyte GA-8I915ME-G Motherboard
Sir am not able to open any of my USB divises..and my motherboard is GA 8i915me..if USB port is a problem,please provide me drivers for that.
http://download.gigabyte.eu/FileList/Driver/motherboard_driver_chipset_intel.exe
if this info is useful to you please vote for me
Feb 27, 2011 | Gigabyte GA-8I915ME-G Motherboard
Up to how many "MB" does the video card slot of my
here are some details for the chipset that provide the graphics. http://www.via.com.tw/en/products/chipsets/p4-series/p4m900/
there is no mention of the maximum memory. but usually you change the allocated memory (on board graphics usually use your systems ram , so the memory you allolcate to the graphics is substituted from you main system memory) in the bios. when you first boot your computer look for instructions on how to enter "setup".
the manual for your motherboard is here.
http://www.gigabyte.com/products/product-page.aspx?pid=2581#manual
Dec 19, 2010 | Gigabyte GA-VM900M Motherboard
Gigabyte ga-81915me dual core support or not
Double check your model number. GA-8I915ME, its not the number 1 to the right of the 8. Its the letter, capitial i.
I did not find your excat model number at Gigabyte, open link below;
http://www.giga-byte.com/Search/Search_List.aspx?Keyword=GA-8I915ME&SearchType=Spec Of the three listed I picked,
GA-8I915ME-C. Than I checked the CPU supported link;
http://www.giga-byte.com/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1954
The GA-8I915ME-C Motherboard supports both dual core & Core 2 Quad.
Hope you find this helpful.
Cheers!
Mike
Oct 16, 2009 | Intel Motherboard
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Gigabyte GA-8I915ME Beep codes
Hi David,
Do you have your manual for the motherboard?
If no? You can down load it from Gigabyte.
Click on this link:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1926
Go to page 76 for the bios beep code description. Your bios is AMI. Click the next link for AMI beep code error descriptions:
http://www.bioscentral.com/beepcodes/amibeep.htm
There are two possible troubles. 1) the first bank of memory has a problem. You can download a program that can test your memory without going into windows. Program is free & allows you to create either a bootable floppy disk or a bootable CD-ROM disk. Click here: http://www.memtest.org/ Scroll down the site until you see, Memtest86+ V2.11. (V2.10)
If your manual is 100% correct than the error is fatal. AKA not repairable but I would suggest you try the above first before tossing the board.
Best of luck David!
Having trouble, post here.
Mike
Apr 02, 2009 | Gigabyte GA-8I915ME-G Motherboard
Open Questions:
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
