Question about Sylvania 7" Mini Tablet
SYLVANIA minilaptop not connecting with visiontek router 83MR . how to set this?
10 rca tablet keeps losing connection have to shut down to get it to connect
Try setting it to a static IP address.
open router settings (type your routers ip address in web browser I.e.192.168.1.1)the admin name and password are normally on the router)then lan settings
set the MAC address of tablet as static noting the IP address (192.168.1.4 for example),subnet mask (normally something like 255,255,255,0),etc.( to find your tablets MAC address settings then about)
when you have set the router up, on tablet tap the settings then wifi, modifiy settings tick use static scroll down and enter new ip address ,subnet mask default gateway(your routers in address).
its easy then it looks.
Sep 13, 2017 | Tablets & eReaders
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
I can not connect to the internet with my zeepad. I bought both of my daughters the same model tablet and they can get on the internet with their tablets.
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Jan 10, 2015 | Tablets & eReaders
My IPAD 2 will not connect to the internet, ir picks up the router but will not communicate
In settings go to reset, network settings.. Make sure your router IP leases rent all assigned, set them for a 24 hour lease time.
reset your router with a 30 second unplug. imthemobile guru
Aug 07, 2014 | Apple iPad 2 Wifi 16GB
I'm having problems with my tablet connecting to wifi I've rebooted my router other devices work fine with it it's not reading the IP address on the router it reconize it but want connect what can I d
You might have something going on in your settings. I remember the first time I tried to connect to a network. It was a nightmare. I was pulling my hair out! You only have one device to connect. I had three devices and none of them would connect until I went in and changed my settings. I hope this was helpful. Good luck.
Mar 14, 2013 | Tablets & eReaders
E-mail problems
Hi. Please make sure that you are connected to the Internet either through wireless or 3G. Browse or search google first to make sure you have Internet connection then setup your email.
Also, double-check your server address and account info. One missing character will cause you delay.
May 08, 2012 | Sylvania SYTAB7MX 7 in. Tablet
I can not connect to wifi
If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Dec 25, 2011 | Tablets & eReaders
I just got a T301 tablet/ereader. I cannot download books for some reason. Any suggestions. I have no idea what I am doing incorrectly. Thank you
LETS CHECK YOUR INTERNET CONNECTION FIRST
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 24, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Sylvania 7" Mini Tablet Logo
13 people viewed this question
Top Sylvania Tablets & eReaders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Matthew Spark
Matthew Spark
Andrew Taylor
Andrew Taylor
Are you a Sylvania Tablet and eReader Expert? Answer questions, earn points and help others
