Question about Peg Perego Vespa Scooter
Wiring to and from rectifier and to charge the battery
1968 Lambretta : Is it possible to help me with the connections to the rectifier which has 3 connections to the bottom and 2 connections to the top?
Please tell me what wire from the generator goes to the rectifier and what wire connects and goes from the rectifier to charge the battery.
    Problem Solver:
  • 12 Answers
I need more info than that, Is it electronic ignition? Call me when you have a chance or check out www.lambretta.net
Posted on Jul 26, 2009
Need diagram for wiring spark plugs
FIRING ORDER
1968 Oldsmobile Cutlass 6.6L 4BL OHV 8cyl
The Firing Order
.Firing order 1-8-4-3-6-5-7-2 ---------front ' 2 4 6 8 ' of ' ' Distributorrotates clockwise vehicle ' 1 3 5 7 ' ---------
Mar 24, 2016 | Oldsmobile Cars & Trucks
Whats the valves should be set at
You mean "what is the tyre pressure on my motorcycle"? Or "what is the valve clearance on my motorcycle"?
Apart from that we would need to know what YOUR motorcycle is? Year, make model?
Post as a comment to this message NOT as a new post. I am one of the motorcycle experts. I started in 1968 with a Lambretta Li150 and finished with a Yamaha 350 YVPS, via all sorts of production racing and endurance bikes.
Nov 08, 2015 | Motorcycles
1968 Mustang w/collapsable steering collumn. Why does the shaft move in and out about 3/8 inch where it exits the fire wall when turning the steering wheel full left to full right
Well, 3/8" is not that much for such a classic car. I would inspect the rag joint and clamp while an assistant moves the steering wheel. Its been awhile since i had the column out, but i would get under the dash with a good light and observe for any movements. Its very possible something is worn and needs to be rebuilt.
Dec 23, 2013 | Mustang 1968 Shelby Gt 500 Kr Gt500 Blue...
The battery of my 2009 Ajs JSM 125 is not charging, how do I check the rectifier?
Find the rectifier. Use a paper clip (you will need two paper clips), a D battery and a single flash light lamp. Test that the lamp will light using your battery and the paper clip. Straighten/bend the clip in a manner that will allow the bottom of the battery to be connected to the side of the lamp. The solder joint on the bottom of the lamp touching the bump on the top of the battery. Disconnect the rectifier from the circuit. Put the light in each position of the four contacts using the paper clips, battery and lamp. The lamp SHOULD light in one half of the connections and should NOT light in the reverse positions. Your Bridge Rectifier is built using diodes. These diodes pass electricity one direction but not the other. Your D battery represents the electricity - the light tells if the power is passing or not. A rectifier is necessary because the Alternator on your motorcycle produces AC current. Your Battery needs DC current to charge. The diode more correctly assists in the 'creation' of rectified AC that looks and acts like DC the battery can use.
I hope this helps you.
Aug 23, 2013 | 2010 AJS JSM Trail 125
I need to fit my dump valve to my audi a6 20v but my dump valve has 2 tubes at the bottom and a nipple at the top can you please help
The 2 tubes at the bottom are to be connected to your inlet pipe as close as possible to your manifold.The nipple at the top ,needs to be connected to your cars vacuum pipe system.
Feb 18, 2011 | Audi A6 Cars & Trucks
The battery wont charge with the bike running
Have you checked all your fuses, are they in good condition?
Check your rectifier/regulator, that is a grey-black squarish box with thin fins under your LH cover with a Yellow and Black wiring on top and I believe a Black and Yellow w/Green strip in the bottom. Use a digital Amp meter to test continuity and get a reading when bikke is off then get the bike running and see what is the reading, when off it should give 0.1 to 1.0 Volt then when running should generate 13.4 to 14.2 Volt. If not hen there is a possibility your rectifier need to be replaced.
Good enough advise?
Jun 21, 2010 | 1994 Honda CBR 600 F(2)R
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
There is 2 strong and 1 light Vertical lines in the middle of the LCD displayed in my monitor
If the lines run from the top to the bottom of the screen and are perfectly straight then your panel is dying and not worth the effort to repair.
Having said that, you maybe lucky enough to find another monitor cheaply and just swap the panels.
Hope it helps =)
Jul 02, 2006 | HP Compaq 1501 15" LCD Monitor
Peg Perego Vespa Scooter Logo
477 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
