Question about Tablets & eReaders
Can't get past android lock screen - Tablets & eReaders
Forgot pin code
Angie, You can may have to do factory reset. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Forgot Lock Screen Password or PIN
http://forums.androidcentral.com/samsung-galaxy-note-2/250290-omg-forgot-pin-can-t-get-past-lock-screen.html
Tablets and eReaders Faq
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Apr 07, 2016 | Tablets & eReaders
Forgot home screem password for android ipad
How to bypass Android's lock screen pattern, PIN or password
trendblog.net > Guides
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
How to unlock an Android phone/tablet - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Forgot iPad Screen Lock Password - How to Recover Data ...
www.wondershare.com > Resource > iPhone
Jan 01, 2016 | Tablets & eReaders
Locked outmy tablet forgot my info to get on
If you cannot get past the password, then take a look through these pages which may help. If all else fails you can use the method for a factory reset, but be aware that you will lose any data stored.
Unlock forgottten password pattern lock of Android Tablet
How to unlock android tablet after forgetting pattern lock
I hope this helps.
I post on behalf of HP.
Jul 18, 2015 | Tablets & eReaders
Forgot pattern screen lock cant get past it
try to google their website you might find the answer there
Feb 04, 2015 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. I don't see any reset buttons or a way to access inside the unit to find one. What do
If a factory reset is required. Press and hold both Volume buttons and the Power button simultaneously; an Android logo with an exclamation mark should appear. Press both Volume buttons at the same time to open Recovery Mode and use the Volume Up and Volume Down buttons to navigate.
Jun 16, 2017 | ZEEPAD Tablets & eReaders
Model q8(a-1) forgot password
Locked android. Forgot google account. Need to reset. How to do this and what buttons to use.
Jan 26, 2013 | Universal Q8 7"" Capacitive Screen Android...
Tablets & eReaders Logo
11 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
